zbph10's Avatar
1987 911 Always blows hot air in cabin
I recently bought a 87 911 Targa and no matter where I put the ventilation controls it blows hot air all the time. I can't drive without the windows open or the top off because it gets so hot in the car. There wasn't an owners manual so I'm not sure if theres a problem or operator error. Any Also where would I get an owners manual?
Old 07-08-2004, 05:53 AM
Friend of Warren
First off, the search button is your friend. Learn to use it. Now assuming your controls work, look between the seats you will find one of these configurations: one or two red levers and/or a console with a knob on top. If you have levers, push them down to cut off heat to the cabin. If you have the knob. Turn it to zero. If neither of those work, jack up the rear of the car, place it on jackstands and check to see if the flapper boxes open and close.
Kurt V
Old 07-08-2004, 06:07 AM
Designer King
Paulporsche's Avatar
The ventilation system is for fresh air only, so it will at best blow air at the existing ambient temp. Only air conditioning will give you cooled air.
If the heater flappers are working correctly, per KurtV's test, then that's as cool as it will be without AC.
Welcome and good luck.
Paul
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-08-2004, 06:16 AM
My flappers were stuck... I'd bet that's it!
Old 07-08-2004, 06:33 AM
mine are stuck now.... hot huh?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 07-08-2004, 06:34 AM
Irrationally exuberant
ChrisBennet's Avatar
If you have auto climate control, the linkage from the servo can pop off. With auto climate you won't have two red control levers between the seats.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-08-2004, 06:37 AM
zbph10's Avatar
I must have the auto flapper control because I do not any red manual levers between the seats. Is there anything special to finding and fixing the flappers?
Old 07-08-2004, 08:40 AM
84porsche's Avatar
Send a message via Yahoo to 84porsche
I second that - I also have hot air in the cabin - when the Targa top is off - it is not as noticeable. Does anyone have pictures of where to find these flappers?
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 07-08-2004, 08:42 AM
Detached Member
Hugh R's Avatar
You can buy an owners manual, a very good quality reprint from Pelican here http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_documt_pg2.htm
Hugh
Old 07-08-2004, 09:26 AM
zbph10's Avatar
Flappers open and close just fine. I found them just inside the rear wheel wells, they were open and a little rusty, I lubed them up and confirmed they open and close like champs when I adjust the dial.
No matter where the flappers are the temperature of the air coming out of the vents is hot as Haitii.
Any other ideas? I sure hope this isn't as good as it gets?
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 07-08-2004, 08:32 PM
A search turn up this thread among others: Auto heat troubleshooting
Try a search using "heat servo" or "auto heat" as the search string.
-Chris
Old 07-08-2004, 08:47 PM
Series900's Avatar
Couldnt resist...
maybe its a loose nut between the steering wheel and the seat, always talking alot of hot air, probably holding a cell phone while driving...
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 07-09-2004, 02:36 AM
I wired mine shut last night ..... for the summer. Worked great and no more hot legs!
Old 07-09-2004, 04:56 AM
dickster's Avatar
the air is controlled using the flapper box and fans - one in the engine compartment and one in each footwell.
so i guess if the flapper box is working it may be the fans? are they on all the time?
does the flapper box shut off the air (i can't remember)? seems the obvious place.
Rich
'86 coupe
"there you are"
Old 07-09-2004, 05:18 AM
zbph10's Avatar
When I turn the heater control into the red the flappers close?
(They no longer take in fresh air) Is this correct?
A fan in the engine compartment and a fan under the dash comes on and the heat is rolling in. When I turn down the heater control the flappers slowly close and the fans turn off.
Everything appears to be working besides it always heating.
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
Old 07-09-2004, 05:44 AM
I will bet you the flapper is open a hair. Mine moved 1/16 when I was convincing it..... and it made all the difference!
Old 07-09-2004, 05:50 AM
Designer King
I don't have the automatic system in my car, but I've noticed that the Bentley manual has some adjustment procedures for setting the controls.
Paul
Paul
Old 07-09-2004, 05:57 AM
dickster's Avatar
the air must still be getting past the flapper boxes.
Rich
'86 coupe
"there you are"
Old 07-09-2004, 06:12 AM
As rich says, air must be still getting by. Although the boxes appear open, there is actually a 'flap' inside the box that must close to stop the flow of hot air. Perhaps these are not sealing. Once the vents on the flappers are open, gently turn them a little further by hand and see if that helps. A slight adjustment might be needed to get them to go further and seal.
2009 997.2 C2S
Old 07-09-2004, 07:04 AM
dickster's Avatar
clayton - i thought there must be a flap inside - thats where i would look.
Rich
'86 coupe
"there you are"
Old 07-09-2004, 07:17 AM
