wheel stud help
Well I broke off a lug nut last weekend and slightly damaged the wheel stud. I was told the threads should be 14 x 1.5mm. I wanted to just get a die and fix the stud, but I can't find that die size anywhere. Anybody know where I can get one? If I can't find one I guess I need to replace the stud. Does anyone know the proper length for a front of a 85' with fuchs wheel? Do most auto stores carry the size?
85' 911 Coupe sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob... |
www.mcmaster.com has the die.
You can order the proper stud from Pelican, your local parts store will not have the correct one. |
Front or rear? You can replace a stud in the front hub in minutes after you get the hub off. Not so easy on the rear.
Where are you? Someone here should be able to give you a stud; there are so many laying around from people installing longer ones. I'm in Long Beach and I've got 10 of them (fronts) in a box, for what? I don't know. Also, correct me if I'm wrong, but the stock studs are different lengths front vs. rear. |
I have the die, Where do you live?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Zeke, it is the front one. Have 6" wide fuch wheel on there.
