Administrator
Jack Olsen's Avatar
Removing glass from rear quarter windows
This is an early car, so it's easy to remove the whole frame from the car.
But is getting the glass out simply a matter of backing out the screws in the frame?
Am I going to have to remove (and reinstall) the rubber seal around the outside?
Old 07-13-2004, 11:42 AM
Chuck Moreland's Avatar
Yes, you just pull the screws. It's pretty easy to take out.
I assume you are putting in lexan?
You can re-use the rubber if it's in good condition. The inside peice is pretty easy to replace. The outer peice is another story.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-13-2004, 11:46 AM
I would rather be driving
jpnovak's Avatar
Yes, you will have to take off the outside seal. It is snapped into the channel.
Once you remove the outer seal, you will see two screws on each side of the front corners. I found it was easier to pull the screws on the curved section. then the end section slides out and takes an angle bracket with it. Othewise, you will have to take those screws out anyway. The glass will then slide forward out of the curved section.
Careful with the screws, they will strip easily and are likely corroded in place. the rubber will likely be stuck to the frame. Careful removing so you can reuse it.
Look at items 23-28 for a parts breakdown.
Old 07-13-2004, 12:27 PM
Slumlord
Porsche_monkey's Avatar
I refuse to respond to any questions about Jack's car that do not include a gratuitous photo.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 07-13-2004, 12:29 PM
Raynald's Avatar
Yes !
I am with you PBH !
i want to see a pic of Jack's car...
Raynald
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 07-13-2004, 12:39 PM
Administrator
Jack Olsen's Avatar
Thanks. I wanted to make sure there were no surprises. It looks like I can leave the seal on most of the frame, but pop off the straight end.
Yes, Chuck, it's Lexan replacing Lexan. I found out that brake cleaner is no good for cleaning tape residue off of Lexan.
And here's a gratuitous photo of the quarter window in question, for my neighbors to the north.
Old 07-13-2004, 03:15 PM
Raynald's Avatar
Thanks Jack !
i am OK now i saw your nice car..!!!
when i exchange mine for a original tinted, i find two size of quarters glass, the early is smaller of the new one's,
Raynald
Old 07-13-2004, 03:59 PM
Are new outer seals available? If so, from whom? Mine are very old and brittle.
Old 07-13-2004, 05:51 PM
