-   -   the ultimate cabriolet thread! (http://forums.pelicanparts.com/porsche-911-technical-forum/172448-ultimate-cabriolet-thread.html)
dfink 11-27-2008 07:23 PM
Hard tops and hard heads.
This thread sure has alot of C.R.A.P.
http://forums.pelicanparts.com/uploa...1226463119.jpg
http://forums.pelicanparts.com/uploa...1226462887.jpg
Feidhlim 11-30-2008 10:45 AM
Replacing Cabriolet Rear Window
The rear window on my '83 911SC Cab split & broke recently in the cold weather. I have managed to get a replacement rear window section but have no idea how to remove the old one and replace with new, and I'm not too keen on just removing screws/bolts and hoping for the best...
If anyone has been through this process and could offer some advise I'd be very grateful.
Feidhlim.
Dublin, Ireland
'83 911SC Cabriolet (Right hand drive)
3.2 CAB 11-30-2008 11:09 AM
Are you saying that you have the entire rear section, that also includes the rear window? If so, the amount of work to replace the old rear section will be sort of a PITA. A lot really depends on how good of condition the front section is. Before you attempt to remove anything, take plenty of pictures, because there is a lot of little parts and some of the larger ones, that just don't look like it would be a certain way, but you will be able to take a look at your "before" photos in order to make sure you get it back together. Also, you need to have pictures of the inside of it also. If you are quite handy with doing carpet, any kind of upholstery around the house, you can probably do it yourself. If you are not very handy at detail type work, it may be better to locate a shop that does this type of repairs and let them do it. If you like feel free to email me for more info.
I replaced my top in 2001 or 2002 and I decided after doing it, that I would never replace another. It is a MAJOR PITA., but it was worth the insanity and work, because my top still looks like new today. I now know, why the shops wanted a small fortune for them to replace the top. There is a lot of hand fitting, trimming, gluing, stretching and adjustments that need to be made to make it look really nice. It is possible for one to do, BUT... it is a real pain, but worth it in the long run. Good luck!! Tony.
Joe Bob 11-30-2008 12:28 PM
I have the Special edition 83 SC Cabriolet supplement from the factory. I could possibly scan it and email the pertinent parts......or mail them.....
Feidhlim 12-01-2008 10:57 AM
Tony,
I managed to get just the rear window section, in the attached illustration it's item #2. The rest of the hood is in good order as it had already been replaced by the former owner due to a 'knife wound' (some people have no respect!). Ideally I want to remove as little as possible to replace the new rear window section, I would hope I don't need to remove the roof section etc., am I being too optimistic?
Feidhlim.
http://forums.pelicanparts.com/uploa...1228157575.gif
Feidhlim 12-01-2008 11:02 AM
mikez, that supplement just might help, scanning/email probably better option than post as I live in Ireland! feidhlimoc@gmail.com
thx, F.
motorcop 12-02-2008 02:48 PM
here's mine.SmileWavyhttp://forums.pelicanparts.com/uploa...1228258063.jpg
CRNT918 12-04-2008 08:05 PM
Daughters car!
http://forums.pelicanparts.com/uploa...1228449847.jpg
JP55 12-04-2008 08:42 PM
and here's my contribution to the thread...
http://forums.pelicanparts.com/uploa...1228452107.jpg
soren.911 01-11-2009 10:57 AM
Anyone recognize this 1974 2.7 updated to a 1983 SC cabriolet..? It should have been driving in the area of Montreal QC, Canada..?
The car came to Denmark last spring and i got it this fall. Its in a very fine condition and i´m interested to hear about some history of the car.
http://forums.pelicanparts.com/uploa...1231699902.jpg
http://forums.pelicanparts.com/uploa...1231699954.jpg
http://forums.pelicanparts.com/uploa...1231699986.jpg
http://forums.pelicanparts.com/uploa...1231700153.jpg
JJ 911SC 10-23-2009 05:33 AM
Nothing too loose
[QUOTE=soren.911;4410944]Anyone recognize this 1974 2.7 updated to a 1983 SC cabriolet..? It should have been driving in the area of Montreal QC, Canada..?
Does look like Soren had any luck... But I'll try the same.
Anyone recognize this 1983 SC cabriolet (CDN Model with Ser # 0070)?
Its probably been converted in Montreal QC, Canada in the late 90's
Cheers
J.J.
http://forums.pelicanparts.com/uploa...1256301116.jpg
jasonmx5 10-23-2009 06:00 AM
C4 Cabrio. All wheel drive and a drop top - how can you go wrong?
http://forums.pelicanparts.com/uploa...1256302806.jpg
Rusty 356 10-23-2009 07:03 AM
http://forums.pelicanparts.com/uploa...1256306544.jpg
I couldn't resist.
Have a great day,
imcarthur 10-23-2009 07:19 AM
It's back from the thread graveyard . . .
http://members.rennlist.com/imcarthu...s-IMGP3263.jpg
My Rules for Owning a 911 Cab
  1. You are the coolest of cool. You are allowed to sneer at all coupe’d drivers. But be kind, because they are ALL envious on a sunny day whether they admit or not. In the picture above, you can clearly see me sneering at Mark in his 930 on the Niagara Parkway - Niagara Falls, Canada.
  2. Top down as often as possible. If you are not top down, the car should be in storage. (or your wife is along for the ride).
  3. Always zip the plastic window out & put a towel on it when folding the top down. This saves the window from wrinkles & cracks & eventual rear obscurity so you might not see that cop car following you.
  4. Practice putting the top up quickly. The only iffy part is zipping the window up - be gentle so you don't rip out the zipper stitching. And THAT is not a fun job to replace - think big sewing needles & blood.
  5. Treat the window with a clear plastic window cleaner every couple of washes.
  6. Never, repeat, never put the top down in freezing temps. I know this breaks Rule 2 but the plastic window is not cheap to replace.
  7. If it starts raining lightly, do not pull over to put the top up. Drive faster.
  8. If your top is manual, always push the metal bar into the fabric as you bring the top down. If it’s not manual, it probably soon will be.
  9. Wash your top every couple of years & spray with a silicone sealant. 303 if you're obsessed or any silicone canvas preservative will actually do the job.
  10. Buy sunscreen & keep it in the door pocket.
  11. Garage the car when not in use.
  12. Never leave the top down for extended periods of time. Always put it up so the fabric doesn’t remain creased & ‘folded’.
  13. When in motion, always have the cab boot cover buttoned down or the top can catch air, chafe & wear prematurely. Another big bill to avoid.
  14. You are the coolest of cool. Keep a pen ready to sign all of the autographs . . .
http://forums.pelicanparts.com/uploa...1256307374.jpg
t951 10-23-2009 09:39 AM
Originally Posted by dfink (Post 4328437)
Where does one get that hard top?
SCWDP911 10-23-2009 10:29 AM
you will have to beg someone that has one to sell it to you.:D Thom Fitzpatrick made some but last I know he stopped and sold all he had left. A friend of mine in Nashville got the last one I think. Looks great on his 84 (his has been updated to 964 look and it now pushes air as well).
Strosek might still make there version, but it looks a lot different and the look is not for everyone. There was one other place I think that made them, but I think they were overseas, and I don't know any more about them...
Of course you couold try to find one of the factory tops...:eek:
dfink 10-23-2009 11:43 AM
From what I have heard Thom still has two tops. I believe a friend of mine is going to buy one so that should leave one. I would call him to find out.
RennLight.com - Church of Speed and Light (Weight) Holy Scriptures perhaps you can get his number off the web site. Of course as mentioned in other threads you could buy my top. It comes with car attached and screamin' 320HP 3.4 only $25K some interior work may be needed ;)
83-911SC cab 10-23-2009 11:51 AM
One more for the show
http://forums.pelicanparts.com/uploa...1256323870.jpg
t951 10-23-2009 11:56 AM
Hats off, tops on
Wow, thanks for the info and links!! As soon as I get re-employed I will be seeing if I can get one of those tops.
philip j 10-23-2009 07:37 PM
couldn't resist
last time I closed my top, the pass side seamed to not come all the way forward! is there any adjustment? Had to manually trip the switch for the motor and pull ahead on the roof for the latch to properly line up to engage in the receptacle. Philiphttp://forums.pelicanparts.com/uploa...1256351811.jpg
