Is it possible to run Weber or PMO carbs on a 3.2 and use the DME to control the spark side? Does anyone make a chip to do that? Is it even possible?
I dont need a bunch of posts from people that wouldnt do it. I already know that.
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
I have heard of this being done. I can't offer any real world experience unfortunately.
I have always liked carbs but not so much anymore. I am actually getting tired of the stincky, troublesome things. I also don't much care for mild cams either. ...so carbs are good in that way. I am actually thinking of going to EFI on my car.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
It should work. Spark is run on a map and is independant of fuel. The only problem will be that you will not be able to optimize the timing for your new found power potential. If you upgrade any internals, you should probably go to an old recurved dist or one of those crankfire units.
1982 911SC Targa 3.6 (now Cabriolet!!!) |
I am running carbs on my 3.2.
I bought a Long Block along with a recurved distrubutor from Henry at Supertech Perfomance in SOCAL. Henry should be able to help you out with any questions you have on the conversion. He has done quite a few of them. His website address is http://www.supertecperformance.com/ Jeff |
Cool. I won't bother him yet. So you dont use the DME at all?
Nope,
With the recurved dizzy we were able to use my original CDI Box. My Car is a 72E coupe. We used Webers, CDI box, New Distributor, and SSIs. I dynoed it last year and got 220 HP and 213 ft lbs of torque at the wheels. I think the Carbs and exhaust made a pretty good difference in the power. |
alot of people just use the 2.7RS type dizzy. ...gotta go back to points or a pertronix though. The SC dizzy spins the wrong way.
we've done a number of 3.2 dme to carb conversions. PMO has the kits or hardware to help you complete the conversion if you have carbs and manifolds already. On the distributor- get a new copper coated drift pin that holds the drive gear on the bottom of the shaft. Remove the drive gear from the 3.2 dizzy and install it on a 2.7 RS dizzy (dizzy available from our host or PMO) Why? the 2.7 rs dizzy has the wrong size gear and will be a little sloppy with timing curve. With headers or SSI style heat exchangers the motor really rocks! easy 250 hp with no other changes
have fun
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
I have a rebuilt set of weber 46s. Will they work on a stock 3.2l?
"YELLORS" 1972 911T with a 3.4l, PMO 46's Vierte Tür Klub Member. PCA National DE Instructor |
Can you just get a chip programed with correct advance curve, or do you really need the 2.7rs dizzy? I remember BA saying they did one and kept the motronics for ignition.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Navin Johnson
I have a 3.2 w/ 10.5: pistons, 20/21 cams, weber 40's, SC distributor ( drive gear swapped, and recurved),MSD 6AL in my 914
its "fun"
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
With the air flow meter unplugged I wouldn't get any advance on my 3.2. Looks like the DME needs the AFM signal to get the advance to move.
Joe |
It doesn't matter who makes the chip, it'll still work, you just won't get the vacuum advance variability without the air flow meter in the equation. RPM dependent timing should still work, and advance timing as the rpm's go up, as you still have an rpm sensor. You could lock the WOT microswitch on and thus be at the ignition curve of the WOT map all the time. The car should still work pretty well, but might not be as efficient at light part throttle loads. I might look into something like a map sensor as a substitution for the vacuum advance signal and feed that to the AFM plug. There are four wires on the AFM plug. Ground, AFM power (about 4.5 volts), afm signal out, and air temp sensor. You could wire the first three to the MAP sensor, and put a fixed resistor of about 2.2K on temp sensor wire to simulate a stock sensor.
Hmmm, this has some promise. Steve, how well will this car run with the carb/motronic combo? Or is the 2.7rs dizzy the only way to go for best performance??
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 07-14-2004 at 05:21 PM.. |
I will have to read it over again, but the engine was a US spec engine with no internal mods. They changed the exhaust and went to carbs and put out some big numbers. I think there is a market for such a chip.....
I would rather be driving
Ruf, You can not just change the direction of the plugs wires on an SC dist. There are two major differences between the SC and the 2.7/3.2 dizzies. First is the pinion gear on the bottom will not mate with the input shaft. Second the weights on the dist are orientated to spin the wrong way. You will have zero advance.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
