| Guest
					Posts: n/a
				 |  944 Fuchs 7x16 - Will they fit a 911?
			I'm asking this question for a German who got a set of 7 & 8x16 944 Fuchs wheels. Both have an offset of 23,3. It's the same offset as normal 911 7x16 Fuchs. This chart however mentions clearance for brake calipers: http://members.rennlist.org/911pcars/WheelWts.html Does anyone know if the 7x16 can fit on a 911SC, at the rear? | ||
|  07-18-2004, 12:00 PM |
| Moderator |
			Yes, either 911 or 944  7s will fit either front or rear of a 911 fine.   The +23.3mm 944 8s can be used on the front of a 911 w/ care to adjust lips and on the rear with ~13 mm spacer. Wheel info also available here
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  07-18-2004, 12:34 PM |
| Guest
					Posts: n/a
			Thanks Bill. I have the 8s up front on mine. I was more worried about the 7s. But if they'll work at the rear as well as the front then it's great. All the German guy needs then are spacers for the 8s and he has a set of wheels for his 911SC.
|  07-18-2004, 12:55 PM |
