			Anyone done this successfully, without machining the rotors down to their wear limit?
				From searching the archives, issues seem to be: a) Later S calipers (Carrera RS style) may have different internal clearance than the early (906 style) ones. Anyone know? b) Have to use the thinner SC pads, rather than the thicker S pads. Makes sense--that 4mm has to come from somewhere. c) The 24mm rotor may have an offset centerline compared to the 20mm rotor. Anyone know? Basically, anyone got proven BTDTs? Thanks!  |
			 Licensed User
			Check out Warren's response in this thread
			A European Car mag. article from a few years ago tackled this mod. They machined the throat from the S calipers to gain the needed space. Not recommended. Maybe there is a different version of the S caliper that won't require this? Maybe others know. SC pads (thinner) for sure.
	Sherwood  |
			So Shuie, did you do it?
	  I saw that thread, and other one had a comment by Bill V that some fit, some didn't.Thanks for the lead, Sherwood. Not much on their web site, but I sent an e-mail to the back issues department.  |
			 Licensed User
			nope, I bought the Carrera calipers, rotors, and a new master cylinder.  Sold my S calipers off in less than 5 minutes on the for sale board.
			The car stops real good  .  I've read that the Carrera setup is considered and upgrade for the track.  I honestly dont think I have seen a difference between it and the S-calipers setup for street driving.
				Re: 24mm Carrera Rotors with S Calipers
	Andy  |
	Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes |  |
 explanation sucks. oh, and Bill's right. Wide As are pretty cheap even new. See my recent thread for the tribulations of buying wide As used, you'll want to buy new
			Andy Last edited by KobaltBlau; 07-16-2004 at 03:37 PM..  |
   Seriously, thank you for all your input and knowledge on this topic even if the discussion veers more towards the speculative than the sensible. ![]() Looks like it was the October 2002 issue of E.C. if anyone has a back issue lying around.  |
			Bill writes:
	"Just use the S w/ the 20 or a wide A w/ a 24. why ask for trouble?" Bill, That's because being able to fit 24mm rotors into S calipers would be nicer than 20mm rotors and without the weight penalty of the wider but heavier iron As (despite the potential flex nature of the lighter Al calipers). What if 24mm rotors are ground thinner to fit inside an S caliper (e.g. 22mm)? Would this be a better heat sink than a stock 20mm rotor or are the vent holes larger in the 24 which results in a thinner 24 having less mass than a new 20? I could take a look as I have both sizes buried somewhere in the garage, but I respectfully ask you, the brake guy out of my sheer laziness to locate them tonight. Regards, Sherwood  |
 Yes, I have seen the S calipers on the 24mm rotors, the question becomes how worthwhile is it. Some folks enjoy the challange more than the result and that is a good enough reason as well Quote:
 I have found that a ~2000# and ~200 hp S calipers on the 20s is fine, w/ approprite cooling, pads, fluid etc. ~2400# and ~200hp the Carrrera setup is similarly adequate. This is for track use for 20 - 30 min stints on a moderately brake intense track like LRP
	Andy  |
			Which presents an additional reason not to try to use an S caliper on a 24.  All the meat would need to come from the out board face of the caliper throat.
