Kolibri
Exhaust stud broke / missing ? HELP
I have been living off of a constant diet of searching past posts with my new endeavor- removing the exhaust. While soaking the nuts for future removal, I went to hit #5's studs and one wasn't even there! It looks like it is not busted off, but vanised! Also , there are no barrel nuts. THe PO's mechanic or the po himself must have replaced them with 11,12, and 13mm nuts? What a slob.
I have been able to easily remove all the other studs with no heating, just liquid wrench sitting for 2 days. I have bought new barrel nuts, gaskets from PP. But my question is, where to get NEW studs? Didn't see them on PP. Are they hidden? I plan on light sand blasting and maybe painting my exchangers to reduce further corrosion. No $$ for SSI. Oh yeah, I bet this is the pfft pfft pfft when cold and clack clack clack when hot, since the area around the missing stud is black with soot. TIA Michael
1942 VW Kübelwagen 1940 Zündapp KS 600 1941 Zündapp KS 750 1975 Volvo C303 TGBII 1967 Honda S90, 1975 CB550 |
Dealer, $2 a piece at most.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Kolibri
$2.13 for each stud and $.25 for the nutz....Good idea to call dealer!
YELCAB1, Do you think a serious exhaust leak could make a clacking sound like others have speculated? regards, MIchael
Yes the clack or pfft sound can come from a loose exhaust connection to a cylinder. I had this happen after my rebuild when one didn't seal well. I pulled the exchanger and ground the surfaces flat then reinstalled with new gaskets and it was fine after that.
Pat
Current: 07 S4 Avant, 06 Volvo S60R Sold: '74 911, 01 986, 93 Volvo 240 |
