right turn signal not working
I'm new to Porsche cars, so please bear with me. All the lights work and the left turn signal works. The turn signal lever feels right. The emergency flashers work. Thanks for any help.
Old 07-16-2004, 09:50 AM
B D B D is offline
B D's Avatar
Have you checked your blinker fluid, it may be low or old? It should be replaced every 3000 blinks.
JK, welocme to the board. It may just be your blinker relay, or it could be at the lever. I would reccomend cleaning and inspecting all the connections.
As a newbie you are required to post pics.
68 911L
Old 07-16-2004, 10:14 AM
Designer King
Paulporsche's Avatar
Check the bulb itself, and its connection in the housing. Also try to trace and check the wiring.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-16-2004, 10:47 AM
joehahn's Avatar
just the front or just back or both rights wont work?
joe 68 L
Old 07-16-2004, 12:22 PM
Both rights don't work. Haven't checked the blinker fluid, but I can tell you the relay pressure is at 120 psi.....(ha,ha)
Old 07-16-2004, 12:51 PM
joehahn's Avatar
have same issue. oddly they worked for a few weeks in the beginning of the season. it's gotta be a ground issue. pull your relay and see if it is the original. pop front trunk, lean over the fuel filler door, stick head in trunk and look right. just past the fusebox there will be a thing that looks like a C battery standing upright. yank it out. does it say hellas on it?
Old 07-16-2004, 12:55 PM
The fuse box is on the left fender. It's a 1985 930. I assume it would be in the same spot? Not by the car now, but will check this weekend and post results Monday. Thanks for all the help so far!
Old 07-16-2004, 01:00 PM
joehahn's Avatar
good god! sorry my man, thought it was an early one. wish i could help more but my average to below average expertise is in the early cars.
Old 07-16-2004, 04:45 PM
Send a message via AIM to fintstone
If your hazards work, it is most likely either your turn signal switch or the underdash six-pin connector for the signal switch. Most of the other components are common.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-16-2004, 08:59 PM
