-   -   Deleting Center Console? (http://forums.pelicanparts.com/porsche-911-technical-forum/172997-deleting-center-console.html)
North Coast Cab 07-18-2004 09:04 AM
Anyone removed their console and found a nice way to finish around teh shifter? I want to install new carpet and keep my leather shift boot. Someone must have made a set-up to allow use of the shift boot. Anyone?
John
Schrup 07-18-2004 09:32 AM
I installed a wevo shifter after I deleted my console & installed an RS carpet kit. It looks simple & clean, form following function.
jazzbass 07-18-2004 09:35 AM
I removed the console from my 85 temporarily when I was pulling out the A/C, and liked it so much without that I decided not to put it back in. Like you, I want to keep the shift boot and have been trying to think of a way to finish it off. My current thinking to to make something out of billet AL (painted/coated black) as kind of a trim ring to go around the bottom and bolt to the floor, hiding the loose end of the boot. I haven't worried too much about it since it doesn't look that bad without anything:
http://forums.pelicanparts.com/uploa...1090168443.jpg
North Coast Cab 07-18-2004 09:56 AM
Chris,
We're on the same wavelength. I was thinking about some sort of trim ring to hold the boot together as well.
John
Trust Me 07-18-2004 06:41 PM
Have you thought about the rubber boot? As you can tell mine is not done but, I am just going to clean up the rubber boot and install the rs carpet kit.
http://www.redlightauction.com/troy/targa%20floor.jpg
carmaneddy 07-18-2004 06:49 PM
I just ditched my boot and polished the shift housing. I think it looks very cool
Trust Me 07-18-2004 06:54 PM
Dude, That angelfire site sends more pop-ups than you can throw a stick at. Can you show me a pic of the polished shift housing? No Angelfire please.
carmaneddy 07-18-2004 07:06 PM
Sorry about the angelfire. I have a popup blocker, but it is a funny website,
Anyhow, here is my polished housing.
Disregard my need to vacuum the carpet :)
http://forums.pelicanparts.com/uploa...1090202750.jpg
Adam 07-18-2004 07:09 PM
Your shifter rod looks very short! Is it hard to shift that low to the floor?
Trust Me 07-18-2004 07:14 PM
adam, Seats sit about two inches lower than factory. Carmaneddy, Thanks for the pic. I like it!
Trust Me 07-18-2004 07:16 PM
Adam, Now that I look. The seats might be like three to four inches lower than stock. Makes the shifter a lot closer.
Adam 07-18-2004 07:54 PM
Cool, Troy. I had a friend in University/College that cut the shifter down like that on his hot-rod VW Golf and while it looked really cool, it made driving fast really hard work.
:cool:
Trust Me 07-18-2004 08:20 PM
Shifter has not been cut. P.O. bought it that way. Actually, pretty easy to shift. You would be surprized. It does let you know if your shift linkage off real fast. Less throw and all. It did take me a bit of time to get the hang of it.
MAS 07-19-2004 12:58 AM
What console? ;)
-MAS
Bob Goding 07-19-2004 02:00 AM
just a thought--saw this on e-bay.au under Audi
might be adaptable--this one is for Hondahttp://forums.pelicanparts.com/uploa...1090227550.jpg
sfmlaw17 07-22-2004 05:38 AM
Go to Google and do a search under "hot rod boot ring" and there will be results for stainless and billet boot ring covers. I have been looking into this as well, but haven't measured to fit yet. I have even considered making one if I can't find one that I like. There are some promising ones at :
http://www.rjays.com/Lokar/Lokar-Boots-Indicators.htm
Hope this helps
JMPRO 07-22-2004 09:16 AM
This is a trim ring i made for my e-brake to keep the rubber from popping out from under the carpet all the time. It screws into threaded holes that were already there. The shift boot ring would probly not be as easy to make because of the different levals unless you use a boot that comes all the way down to the carpet.
Jerryhttp://forums.pelicanparts.com/uploa...1090512965.jpg
v9ff 07-22-2004 09:35 AM
Jerry,
You have more machining tools than any man should have in his garage! I'm waiting for you to appear in an episode of "Overhauling" or something tricking out a 911. Ring looks nice. :)
}{arlequin 07-22-2004 09:56 AM
Jerry, that is a really nice idea. Would you be able to post a life-size outline drawing of that ring? Or did you just "wing it" and trim/machine as needed?
JMPRO 07-22-2004 12:09 PM
That part was made with just a drill and a jig saw out out 3/16 alum. I don't have any fancy equiptment although i did add a band saw to my arsenal. I did'nt do any drawings, i just winged it by using the general shape of the boot and filed and trimed as necessary. Now i looked back at my picture, i see the part needs to be repolished and cleaned.
Jerry
constructicon 07-22-2004 12:14 PM
Man, they look good without the console. The Targa I inhertied has the 8-track holder in the console. I'm not sure if I should leave it there for nostalgia, or toss it eventually. I didn't realize 8-tracks were still around in 84. Of course, I was only nine, so what the hell would I know.
North Coast Cab 07-22-2004 12:21 PM
So you can end tha carpet at the base of the shifter houseing. Polish the shifter housing base and use any boot you'd like. We just need some osrt of band or ring to go around the bottom of the boot and button things up. I'd really like to keep the leather boot I have. The "hot rod boot ring" could be the ticket.
John
JMPRO 07-22-2004 12:25 PM
You need somthing thick enough you can screw down to the floor with out buckling or the ring will just move around every time you shift.
Jerry
Thrasher 07-22-2004 01:02 PM
if you're pitching it...and it's black
The center console insert on my '84 coupe is cracked at the speaker fader pot. Since I have (and need) working A/C I don't think pulling the console will work for me.
I really only need the insert piece, but I'm not sure how it connects to the rest of the center console.
I'll gladly pay for shipping and a fair price for the piece.
THanks!
Craig
