-   -   Odometer not working (http://forums.pelicanparts.com/porsche-911-technical-forum/173038-odometer-not-working.html)
sagacis 07-18-2004 01:08 PM
My odometer doesn't work (apparently very common). So I took apart my speedo to see why. The lamp holders were a b!tch to get out. In the process, I pulled out one of the lamp wires. I think I can just jamb it back in, but should I try to disassemble the holder and re-crimp?
Anyway, here's what I found. This is the gear Rennbay sells, right?
http://forums.pelicanparts.com/uploa...1090181279.jpg
When I touched it (on the left side in the picture), a tooth disintegrated.
jester911 07-18-2004 02:24 PM
That is the gear that always goes. I don't know about rennbay gear. That option was not around when mine broke so I had to take it to a speedo shop. Since you have it apart it is worth a shot.
Erakad 07-18-2004 04:15 PM
Check the archives. The cost to replace that gear is about $25. You can get the gear at www.odometergears.com. There are a couple tricks, suggest the archives check and technical bbs.
OBTW, if you have a ROW...make sure you get the right gear. Would pay to check.
GL
Formerly Steve Wilkinson 07-18-2004 05:30 PM
The reason these gears strip, by the way, is because people try to zero the odo with the car under way. Do that at a standstill or don't do it at all.
Stephan
greglepore 07-18-2004 05:51 PM
Odometergears.com has the gear. Getting the speedo needle off to effect the repair is sometimes an adventure. In any event, if you've got it stripped that far down, its worth the 25 bucks.
