Crane HI-6 & LX92 Ignition...
Is anyone using one of these babies on their 3.2 Carrera?
Would like some feedback on their performance and installation etc... Crane HI-6 vs MSD 6AL
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
I would rather be driving
Sorry, not a carrera but I have one in my carbed 3.0. Sems to work quite well.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
RETIRED
I have one on the 2.0 and the 2.2.....work fine. Needs a tach adapter in some cases.
Also have it w/o the coil in the Dodge with the blower....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Cool, anything has to be better than the factory suff, especially when trying to keep up with 550HP
![]() I seem to be experiencing what seems like ignition break-down under high loads, so I'm hoping going to an aftermarket unit like this will cure the problem. Juan had similar problems when he was at 404RWHP
if so tighten up your plug gap a little to keep the boost from blowing out your spark. try staring at 28 tto 30 thou and then go open it up till the misfire occurs the close them up just a little.
Excell Racing Boca Raton fl |
An aftermarket ignition box may be what you need to offset the boost pressures snuffing out the factory spark. However, make sure all the ignition components are up to spec (dist. cap, rotor, plug wires and plugs) before investing heavily.
Sherwood |
ssetek, yes under load. The problem has just surfaced, which is really annoying
![]() Plugs are 993tt units. Ignition leads are 8.5mm Magnecor's. Ran fine for a couple weeks (since complete engine rebuild), but seems like something in my ignition has broken down. Checked for any loose hoses/pipes and there are no vacuum leaks, so it must be my crappy old Carrera ignition system. Can't be my fuel pumps because I'm running two BOSCH 044 700HP fuel pumps ![]() This is all happening at 1.0bar boost. Imagine what happens when I run the full 1.25bar the system is design to run at ![]() The ignition needs to be upgraded anyway because I intend to hook up my twin-plugged heads soon
Can you use that with a motronic? I had one on my 2.7 and it worked great. I can't imagine it would do anything for a 3.2 though.
Chris '75 911s 3.2 - Ice Green Metallic ‘87 951, '05 987 S '21 Jeep Gladiator ‘18 Tesla ModelX 100D, ‘20 Model 3 |
Merv,
Let's step back a little and describe some of the high load symptoms you're experiencing. Do you know the spark advance, cylinder head temps and A/F ratios at 1 bar boost? Sherwood |
The problem is just more prevalent at high loads, but it does it under light load too. Even at cruising speed at constant throttle I can hear popping.
It doesn't only happen at 1bar boost. I've turned the boost down to 0.8bar and it still hesitates/misfires. Haven't had the car on the dyno to map the A/F ratios yet. I checked all the spark plug leads and connections and all seems OK. I guess I can just go out and get a new coil. Maybe it's a weak coil? I have noticed now when I get out of the car, the door handles intermittently gives me a bit of a zap and that's never happened before with my car. Maybe it's a bad ground somewhere or a short? Started the car in the dark to see if there are any spark leakages anywhere but couldn't see anything. I don't have the tool to remove these plugs, so I can't check gaps etc. Since I'm using 993tt plugs, the gap would be 0.8. Protomotive recommend the 930 W3DPO plugs for there systems, which use a 0.6 gap. Not sure if that makes a difference because it was running fine up until a few days ago ![]() Hoping the Crane HI-6 and LX92 will cure the problem
merv,
seems like a sledge hammer to crack a nut if you don't know the cause. and it was running fine previously.......
Rich ![]() '86 coupe "there you are" |
only a guess that it's running lean enough to spike your EGTs.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
This is odd...as the Carrera ignition system can flat put your Arsch on the ground if you mishandle it while troubleshooting.....
All we need to do is look at Porsche's racing 934's and 935's that may be developing similar boost and HP. Were there chronic ignition problems with these cars...using even more ancient ignition systems?? I don't really think so ........hmmm... ---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Merv,
My seat-of-the-pants assessment is that there's something going on with the factory ignition system. You should not have any part throttle, low-load ignition problems with a system in good health. Perhaps installing new components will fix it, maybe not. I would have it diagnosed at a pro shop. It might be cheaper in the long run. Maybe a dyno shop can find it as well as provide an A/F and spark map at the same time. Sherwood |
The consensus of the board is generally that you can't beat the Bosch unit for reliability, and that these aftermarket boxes deliver a bit less than their marketing may lead you to believe. Do you have access to another CDI box you could plug in to determine whether that is your problem?
Ken 1986 930 2016 R1200RS |
Nope, don't have access to a spare CDI box
![]() I've already ordered the HI-6 & Coil anyway, which should be here early next week. I'm having it installed together with a Haltech Haltuner A/F meter (AFTER checking plugs etc). If the upgraded ignition doesn't resolve it, then the A/F meter will surely tell me if there's any lean condition happening throughout the entire rev range. Suffice to say, I've turned the boost way down low to 0.8bar and I'm still having the same misfire problem, which tends to point more towards a spark/ignition/electrical issue, than fuel starvation. Exhaust tips are black as, which tends to indicate too rich a mixture and unburnt fuel which could explain the faint popping at light/cruising throttle. In a few months I'll be ripping out the archaic Motronic system anyway and upgrading to an Autronic SMC setup and 964/993 dizzy to my twin-plugged heads. Should make the car feel like a totally different animal.
Hey WydRyd, I'd be interested in that run-down old 6 Pin CDI box if it's all the same to you.
Can you please contact me at yorktown6@optonline.net Thanks Ken
Here's an update folks:-
Started the car this morning and the battery light stays on much longer than usual. Car idles for a while and the battery light slowly goes off. Car intermittently (but more frequently) idles a lot lower than usual (around 500-600rpms) Sometimes the RPM's float at idle and then drops down again. Turn the headlights on and the rpm's drop by 100-200rpms. Turn the stereo on and pump up the volume and the lights on teh dash tend to dim ![]() I think I may have a slowly dying alternator The battery is quite new (only a few months old). Will test the Alternator output and see if that's the case. Grrr!!! Possibly a voltage regulator or Alternator? What do you guys think?
