Creating RS rocker decos
I really like the looks of the RS Touring, with the curved rocker deco that matches the flare. Has anyone out there ever bent a standard rocker deco to create an RS deco? Can it be done?
Edit: Whoops, I thought you meant the bumper deco.
The deco trim can be bent, carefully, but it comes up a little short when you add the increased distance with the flare. It makes it harder to fit the end caps. Doesn't anyone make an RS-specific piece? http://members.rennlist.com/jackolsen/Roadside-M.jpg |
I think you're referring to the molding under the door?
Yes, I've seen it done and even tried it on the ones I pulled off my car. Extra patience is required, bend in small steps, test fit, bend again. |
Thanks, Todd, and yes, Jack, Stoddard has the correct RS rocker deco but it is nearly $200 each side. I don't like the look THAT much! I have some old beat up trim to practice with before I try it on my new ones.
It's soft Al. Make a buck and ben it over that. You can play Walter Mitty and pretend you are beating out the panels for the original 356....
| All times are GMT -8. The time now is 02:13 PM. |
