Creating RS rocker decos
I really like the looks of the RS Touring, with the curved rocker deco that matches the flare. Has anyone out there ever bent a standard rocker deco to create an RS deco? Can it be done?
Old 07-19-2004, 08:02 PM
Administrator
Jack Olsen's Avatar
Edit: Whoops, I thought you meant the bumper deco.
The deco trim can be bent, carefully, but it comes up a little short when you add the increased distance with the flare. It makes it harder to fit the end caps.
Doesn't anyone make an RS-specific piece?
Old 07-19-2004, 08:25 PM
Todd Simpson's Avatar
I think you're referring to the molding under the door?
Yes, I've seen it done and even tried it on the ones I pulled off my car.
Extra patience is required, bend in small steps, test fit, bend again.
Old 07-20-2004, 08:58 AM
Thanks, Todd, and yes, Jack, Stoddard has the correct RS rocker deco but it is nearly $200 each side. I don't like the look THAT much! I have some old beat up trim to practice with before I try it on my new ones.
'56, '59 356A Coupes
'67, '68 912 Coupes all gone
'72 911T coupe
Old 07-20-2004, 04:51 PM
Randy Webb's Avatar
It's soft Al. Make a buck and ben it over that. You can play Walter Mitty and pretend you are beating out the panels for the original 356....
Old 07-20-2004, 07:42 PM
