Rear Sway Drop Link Bushings
Can I just replace the rubber on the rear sway bar drop links? I can't seem to find anything on Pelican. It's an '84 for with a later 21mm sway bar.
Thanks, John |
No, you need to replace the whole drop link. They're only $35 ea, and take only 10 min. to replace.
Mine look like this
http://forums.pelicanparts.com/uploa...1090369975.jpg The ones on Pelican look like this. http://forums.pelicanparts.com/uploa...1090370025.gif John |
Or you can upgrade to these as I did. They are Tarret adjustable rear drop links. The host sells them.
http://forums.pelicanparts.com/uploa...1090370359.jpg |
Paul,
Those are sweet. What does the off center bolt thing do? John |
John, the ones I bought from Pel. are the same as in your pic. Call, the sales dept. They can help you.
4 Heilm Joints for $130, seems a little outrageous. I'll see if I can locate.
John |
Not so outrageous...
I've paid that much for ONE heim joint used on a formula car upright.
Nice item though.... Chris |
Heim joints (observe spelling) are common. Do a Google of Froggle.
Common yes,
Equivalent no. In this case, if it breaks, no major catastrophe. On the other hand, if this is on an a-arm, you need to be a bit more discriminating...
Chris |
CBracer - You think they are made of a special alloy?
Those adjustable drop links are designed to connect to the spring plates instead of the trailing arms (as the factory links do). They connect to the toe adjustment on the spring plates, hence the eccentric which replaces the factory toe adjuster. So yes, there are some custom made parts there in addition to the 4 rod ends.
Chuck, any idea why these statements appear on Tarret's web page? Are they marketing the item to be used in a different manner than they were designed?
"Upgrade your stock swaybar with this simple bolt-in replacement for the factory drop links. Adjustable length to eliminate swaybar preload. Oversized, precision Teflon-lined rod-ends for long life, smooth operation, and high-reliability. Eliminates the factory compliant rubber drop link bushings for improved swaybar response. Precisely connects the stock swaybar to the rear trailing arm." http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_suspen_pg5.htm#item12 http://www.tarett.com/911_rear_drop_link.htm |
Randy,
I don't think these are particularly special heim joints, they look pretty average from the photo. My comments are simply noting that the cost does not seem outlandish for the product, and 'sourcing your own' may not really save you any money (given there are a couple of custom machined parts there also). Cheers, Chris |
I assume their adjustable drop links offer similar attachment choices. In any event, that is what those eccentrics pictured are for - spring plate attachment. |
| All times are GMT -8. The time now is 04:13 AM. |
