New Clutch wont work!!?
HI every one my wrench buddy called and said he cant get the pressure plate to pull .A Little back ground newmotor and clutch and plate in a 77 911s. he has alot of experience 10yrs with 911s.we got the engine back from the rebuilder also very competent he is out of town at Lemans. were stumped tried all the usual stuff as far as adjustments cable helper spring ect .But to no avail pressure plate will not pull .any advice would be most appreciated!! thanks Chuck
Old 07-22-2004, 05:13 PM
North Coast Cab's Avatar
I'm not an expert, but the fork is probably not engaging. When you mate the tranny to the motor it's critical that it falls in place. Not sure if there is an easy fix without removing tranny again.
John
1985.5 944 GTS
Old 07-22-2004, 05:15 PM
H20911's Avatar
does the pedal move and pull but the clutch will not release or does the pedal just not move at all?
h20911's V8 Homepage
www.home.earthlink.net/~sdfranco/index.html
Old 07-22-2004, 05:20 PM
pedal does not move and is very stiff
Old 07-22-2004, 06:05 PM
he didn't get the fork engaged with the throwout bearing is my guess. then the fork just backs up into the bellhousing and the pedal can't move.
206 637 4071
Old 07-22-2004, 06:08 PM
I am guessing that you should check in this order.
1. Disconnect the cable at the tranny to see if the cable moves. I bet it will.
2. Then you inspect the omega spring to see if it is in the right place. If it is,
3. Drop your engine and remove transmission. You will find that:
a. Fork is bent, not engaged,
b. Center shaft is bent, or not greased
d. you have installed the clutch wrong.
good luck
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-22-2004, 06:11 PM
thanks for advice an info JW and yelcab Ill check it out and post again
Old 07-22-2004, 06:40 PM
