Bride of Frankenmuffler
Team project between Valvefloat ('68L) and MT912RS.
First you need a plan: Supercup look and it sounds great! |
Nice welding! Any detail on the components used for the muffler halves?
Warren & Ron, may you rest in Peace. |
Kind of like this.
So, was the center section fabricated from scratch?
Yes, we started with a couple sheets of 22ga steel, and a few feet of 2" exhaust tubing.
Joe 1993 C2 |
Very nice work!
72 911S with 3.2 and RS body work http://www.angelfire.com/nc2/mycoffeecan/page1.html www.pelicanparts.com/gallery/carmaneddy |
Pretty cool. What CAD system did you use for that?
Timothy
Tim 1983 930 w/ goodies |
SolidWorks SketchoCad
Joe 1993 C2 |
Senior Member
Oh yeah.... Well... I Came Up with the name!
-- Chief Architect and Mastermind, SCWDP |
But the real question. How does it sound? ;-)
Matt B '73 911E |
You guys should go into business. There is a market for custom inlet and custom outlet mufflers that are reasonably quiet.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 03-15-2004 at 03:17 PM.. |
hmmmm... perhaps we will.
How about fabbing a nice light wt. muffler out of Ti?
"How about fabbing a nice light wt. muffler out of Ti?"
.... and to make it even more of a challenge (you like challenges, yes?), make it affordable too. Sherwood |
Interesting! Neat stuff.
I have always wondered about the insides of mufflers.... So, a few questions.... Performance?? Any gains? Sound? Loud? quiet? Any air rushing or turbulence noise? Weight? Any packing?? If so, what? Stainless? Did you do any designs of one with outlets on the ends? Thanks!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Cool. Reminds me of a custom muffler I designed for my 911SC many years ago. I had the stock exhaust with the European pre-muffler (sits where the catalytic converter goes on American exhaust). I removed the muffler and had a machine shop bend me an exhaust pipe to come straight out the pre-muffler and curve to exit where the stock muffler exhaust pipe was. They welded a flange on it so it bolted right up to the pre-muffler. It was maybe a foot long overall and removed a fair amount of weight from the very back of the car. At low RPMs it sounded like a truck, but at high RPMs it sounded like something off the track. I called it the Wunderpipe.
I have to add that the Wunderpipe was not as well thought out or designed as the Bride of Frankenmuffler. I didn't even have SketchoCad. Nice work. Thanks for the post. How about some sounds files??? Rob
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
That is some pretty neat work, guys!
Are those aftermarket headers that caused the long & wide separation inlet pipes? Bursch??? So, let me see if I got this straight ... you went from the basic idea. inspired by the factory banana, modified to sport muffler -- Solidworks 1, simplified actual layout to solidworks 2, right??? 1st iteration: ... to final refinement/simplified for ease of assembly/fabrication: ... producing the final product: One final questiopn ... how did you form the sheet into such a perfect circle?
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
It weighs less than a stocker, but we didn't weight it before it went on, we were too excited to hear it. There is high temp fiberglass around the perforated pipes. This proto is mild steel, but we have talked about going to stainless on future ones. Quote:
We went through a few design revisions trying to figure out an easy way to build it. The one we built was done in halfs mostly because we couldn't get material long enough locally. Quote:
Joe 1993 C2 |
Joe 1993 C2 |
