-   -   1994 3.6 turbo idle speed (http://forums.pelicanparts.com/porsche-911-technical-forum/173676-1994-3-6-turbo-idle-speed.html)
slfergy 07-21-2004 09:02 PM
I just bought a 1994 3.6 turbo and had a 60,000 mile service done but the idle speed is at 1200 rpm, with a/c on it's 980 rpm
I think it should be 950-980 RPM but it's real consistant so i think no cable problems. Does anyone know what to do except take the car back to 60,000 mile service guy who lives 12 hours away?
Thanks Stacy
eyue 07-21-2004 10:31 PM
My 93 3.6 turbo(23000 km) idles @1200 rpm when start cold in the morning, afterwards it stays around 950 rpm, and with A/C ON, drops to around 800-850 rpm.....SmileWavy
JNadal 07-22-2004 04:11 AM
You're just trying to brag that you got a 94 Turbo ;)
How do you like it so far?
iobound 07-22-2004 04:38 AM
My 92 Turbo idles at about 900 when warm and about 1200 when cold but only for about 20-30 seconds before it settles down to normal idle.
The idle speed adjustment screw is at the front of the throttle body which sits under the intercooler. I use a 12-14" flathead screwdrivers to reach it. Start with small adjustments like 1/4 turns. If that makes no change to the idle speed then you know you have to start down the diagnostics road. There are a lot of good CIS guys on this board. I'm not one of them :-)
