Need Help Wont Start
Drove for a mile yesterday, stalled and stopped, smelled burning plastic under the seat, REPLACED the DME relay, tried to start, smell gas, NO start Please advise starter is working fine, New battery constant voltage, checked last week, a Mystery. Thannks!!! John
gas leaking from transmission area
gas leaking from trying to start in the transmission area, Flooded??? Thanks. John
Well, you do have fuel i guess by describing your symptoms.
Make sure you have sparks and air !!! Good luck, Phil. |
Did you confirm that the DME relay was actually damaged (burned)?. Check and make sure the DME relay socket didn't suffer any damage. One of the connectors inside the socket could have burned up and is still not making contact with the new relay.
IN the Shop as we type
It will be interesting to see what happend since I said UNCLE. Thanks for the help. John
| All times are GMT -8. The time now is 01:25 AM. |
