John M
jmarenas's Avatar
Question Need Help Wont Start
Drove for a mile yesterday, stalled and stopped, smelled burning plastic under the seat, REPLACED the DME relay, tried to start, smell gas, NO start Please advise starter is working fine, New battery constant voltage, checked last week, a Mystery. Thannks!!! John
"I Can't Drive 55!!
Old 07-26-2004, 12:41 PM
John M
jmarenas's Avatar
gas leaking from transmission area
gas leaking from trying to start in the transmission area, Flooded??? Thanks. John
"I Can't Drive 55!!
Old 07-26-2004, 12:45 PM
Well, you do have fuel i guess by describing your symptoms.
Make sure you have sparks and air !!!
Good luck, Phil.
Old 07-26-2004, 05:30 PM
david914's Avatar
Did you confirm that the DME relay was actually damaged (burned)?. Check and make sure the DME relay socket didn't suffer any damage. One of the connectors inside the socket could have burned up and is still not making contact with the new relay.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 07-26-2004, 07:33 PM
John M
jmarenas's Avatar
IN the Shop as we type
It will be interesting to see what happend since I said UNCLE. Thanks for the help. John
"I Can't Drive 55!!
Old 07-27-2004, 10:26 AM
