-   -   Left/Right Spring Plates - Interchangable? (http://forums.pelicanparts.com/porsche-911-technical-forum/174574-left-right-spring-plates-interchangable.html)
vesnyder 07-27-2004 05:13 AM
I am getting my spring plates cad plated and am curious if the spring plates are interchangable from side to side? - I assume not a best practice? What is the best way to mark them before going to the plater?
I will share before and after pics when I am done!
Rick Lee 07-27-2004 06:07 AM
I don't know how you could mix them up. I don't think they are interchangeable, even visually. I have a set of Sway Away adj. plates sitting here in my office, but don't have any stock ones handy to look at. I think there are upper and lower bolts on them.
jyl 07-27-2004 06:13 AM
I vaguely recall the angle of the plate arm where it connects to the tube part distinguishes R from L. How's that for precise.
Edit: Sorry, my bad.
Shuie 07-27-2004 06:17 AM
When I re-assmbled mine after plating I couldnt tell the difference between the parts that were on the RH andLH sides of the car originally. I hope I did everything correctly.
jpnovak 07-27-2004 07:06 AM
Stock spring plates are interchangable. Both the early fixed and later adjustable. the splines may be slightly different but you will have to reindex upon installtion anyway.
vesnyder 07-27-2004 07:27 AM
They sure looked interchangable - thanks for the clarification Jamie. I notched the passengers side just to ensure it goes back the same way.
Now if I could get them separated I could get them to the plater!
