Ride Height Front to Back ratio
I know that ride height is a personal preferrence, but, is there a general rule as to ratio from front to back. I have tail and chin spoiler installed however is there a proper relationship beteen front height and back?
For example, should the front be x inches (mm) higher or lower than the back? This is for a street car so I'm not concerned with track setup.
Michael
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 07-27-2004, 08:42 AM
Fender height in front should measure 0.5 inches higher than fender height in the rear. This gives a 1-degree downward rake to the car.
According to Bruce Anderson.
Old 07-27-2004, 08:58 AM
Designer King
Paulporsche's Avatar
Measure up from the floor, or road surface, through the center of the wheel to the top of the wheel arch opening to get this dimension.
Bruce recommended 25.5" front and 25" rear for those using 15" x6 and 7" wheels and 195/65 front and 215/60 tires.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-27-2004, 07:56 PM
Now in 993 land ...
aigel's Avatar
Read your bentley manual or the 101 projects book and go with the euro ride height. Measure from center of wheel to center of torsion bar for an accurate setting. Fenders, tires and wheels can lead to large errors in fender lip to floor measurements. HTH,
George
81 SC (sold)
Old 07-27-2004, 08:06 PM
Before I lowered mine last summer, I went around measuring the fender heights of all 911's I could. The lowest I found was 24" F 24.5" R. There were several clustered around the so-called Euro height of 25.5 F 25 R. I finalled settled on 25 F 24.5 R and have been happy (car started at 26.25 F 26.75 R !!!). Two comments:
1. I have to be very careful in and out of some parking lots.
2. I could not reach factory specs for camber, had settle for a little more negative. After more reading this sounds like a good thing and I plan to go even a bit more negative at some point.
I recommend corner balancing after lowering, if you can find some wheel scales.
Also, I could never make sense out of the Bentley method of measuring ride height.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 07-27-2004, 09:34 PM
Now in 993 land ...
aigel's Avatar
It isn't good for checking out someone's car or getting a rough idea, but to set the ride height, there is no other method.
It's easy. Measure wheel center to floor. Measure center of torsion bar to floor. Subtract. And voila, there is your ride height.
This method takes all the body variation out, also, the wheel center doesn't care what tires, rims, inflation etc. you run. All you need is a flat and level surface to work on.
Cheers, George
81 SC (sold)
Old 07-27-2004, 09:43 PM
