remove both vac lines to time a 1980?
I'm just fine tuning and will be rechecking my timing. Bentley isn't specific...do I remove both vac lines from the distributor before timing to Z1 at about 950 rpm with the engine warm?
Thanks, Graham |
Yes I believe you do remove both lines. But I think you want to set total advance at 4k rpm. Then you check the idle advance.
Dean |
both hoses off, turn down idle to 950, set timing to spec, reattach hoses and reset idle speed.
| All times are GMT -8. The time now is 10:21 PM. |
