Is this caliper correct?
I went to install the speedbleeders I ordered for my '75 911S. I was sent two pairs of 7x1.0mm bleeders, and they fit fine on the rear calipers.
But the front calipers have TWO bleeders each, and they are 10x1.0mm. I should have checked them first. Question1: Is this really a stock caliper for the '75 911s? Question2: How do I bleed them? Crack one bleeder, bleed, then close it and do the other one? Thanks Colin http://forums.pelicanparts.com/uploa...1091164663.jpg http://forums.pelicanparts.com/uploa...1091164678.jpg |
That's an "S" all right.
Why not give her a good clean up while you have it off? I always bleed them from the outside to the inside. http://forums.pelicanparts.com/uploa...1091165401.jpg |
Cowtown, I just finished the same project last night. Yes, that is the correct caliper and has two bleeders. That is an S caliper (aluminum).
Can you put my mind at ease and tell me if that is the top of the calliper in the picture. I can't remember when I took mine off if the bleeders were on the top or bottom. |
Speed bleeders kick butt! I love them on my calipers. Open, pump, close, next.
yes you have S calipers. They require a different size bleeder screw. |
poorsha, did you get it looking that good from just a cleanup, or did you have them anodized or something?
RallyJon,
"spit and polish" (and some Simple Green). I also installed the Stainless pistons. I am amazed at the condition of everything on my 74 (except for the paint). Not a single frozen nut or bolt. The brake backing plates cleaned up the same way (they are out for plating along with just about everything else).I am taking a lot of pics. |
Poorsha,
Can you confirm which is the top of the caliper. Do the bleed screws go on top? |
They are on the top.
Thanks you guys. These "S" calipers are so much nicer than the ones on my old '88 that they confused me. The '88 Carrera had a big heavy steel caliper with one bleeder.
These are so light and good lookin'! Colin |
poorsha, that caliper is stunning. i think the bleeders are on the top to let the air bubbles that float a easy way out.
do speed bleeders make the motive power bleeder obsolete? or redundant? |
Thanks vash.
Nothing goes back on without a good cleaning. |
| All times are GMT -8. The time now is 03:11 AM. |
