WydRyd's Avatar
Replacing Cabrio rear window?
Hey gang,
What's the typical cost to replace just the rear plastic window on the Cabriolet? Mine is so bad now that I can't even see through it!
I'd like to get a Trimmer to replace it, but just curious as to whether anyone here has done theirs and could tell me what sort of $$$ I would be paying to have it done?!?
Actually, the whole roof looks aged/faded & needs replacing! I actually considered replacing the whole thing with a new 993 top, but it's a bit out of my budget right now. Maybe something to do when I eventually do the Patritti 993tt body conversion
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 07-31-2004, 07:10 PM
Buy them, sell them
Adam's Avatar
Merv, I need to get this done, too.
I've been asking around here in Melb and most trimmers agree that the entire roof needs to be removed before they can go change the window.
I'm chasing pricing now and I'll PM you if you want. Might be able to get it done cheaper for two.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 07-31-2004, 09:07 PM
WydRyd's Avatar
Hi Adam,
I'm told that these windows can be replaced fairly easily by a competent trimmer for around the $200-$300 mark. The complete roof does NOT need to be changed. I think they've got their hands "on it" there.
I'll do some research too, so let's compare notes soon
Merv
'89 911 Turbo Cab
Old 08-01-2004, 07:16 AM
jgporsche's Avatar
Unfortunately the two piece top is glued/attached and stretched on to the rear bow. One has to remove the front piece to remove and install the back piece.
I’ve been told that the front piece won’t survive removal if it’s too old. My front piece had been replaced by the PO, but my rear needs to be replaced. PO had raised roof on unleveled ground then forced it closed, bent both sides. Had a receipt for close to $3000 to repair it, yet didn’t have back window replaced. Probably was taken advantage of. I have a new rear section (back window) to install, just haven’t found directions on how to install it.
1994 968 "Totaled during practice for GBRS / PCA 2009 Race season"
1989 944 Track car replacement. Complete with 968 running gear.
1988 911 Carrera "Friday / Weekend Driver"
1988 944 Daily Driver now.
1973 911S "In storage"
Old 08-01-2004, 09:03 AM
I just had this done a couple months ago. Yes, they have to remove the entire top, and they ripped a small part of the main top ungluing it. They suggested I replace the whole top, but it was out of my budget.
The cost was $400, which would be ~$1200 AUS
Old 08-01-2004, 10:20 AM
