Send a message via AIM to jgiroux67
Am I missing something? Calipers
Just got these 911 Sc calipers. Am I missing some pieces from them? I am not familiar with these so I dont know. It looks as if there is no pistons or is that what it is supposed to look like.
73 2.0L 914
Old 08-02-2004, 02:46 PM
disband
juanbenae's Avatar
the rusty part in the center is the piston, around that the rubber is the dust cap. those need a rebuild before putting them in service.
Old 08-02-2004, 02:49 PM
another
73 2.0L 914
Old 08-02-2004, 02:50 PM
last one
73 2.0L 914
Old 08-02-2004, 02:52 PM
vash's Avatar
http://www.pelicanparts.com/techarticles/911_caliper_rebuild/911_caliper_rebuild.htm
poof! gone
Old 08-02-2004, 03:25 PM
Bland
unclebilly's Avatar
I'm rebuilding mine in my 77S right now. The frozen pistons area real ***** to remove. Any ideas beyound my vice grip on the smaller diameter part and trying to wiggle and giggle?
I got the backs done OK and am now fighting with the fronts.
BTW, there is nothing missing on those calipers except for the pins and clips that hold the pads in.
Old 08-02-2004, 07:08 PM
dtw dtw is offline
GAFB
jrigoux: Yeap, they're all there. You've even got caps on the bleed nipples.
unclebilly: Use air to force 'em out. Do a search, there's lots of threads on brake overhauls.
Several BMWs
Old 08-02-2004, 07:22 PM
Bland
unclebilly's Avatar
I tried air. They're in there pretty good. I'm thinking about hooking them back up and stomping on the brake pedal...
Old 08-02-2004, 07:30 PM
vash's Avatar
unclebilly, i used a bike pump. watch your fingers!
poof! gone
KobaltBlau's Avatar
that is one of the surest ways. try it!
Andy
Old 08-02-2004, 08:10 PM
Send a message via AIM to Oldporsche
Cool
I knew a guy that touted the use of a grease gun. He produced an adapter to either the bleed nipple or the brake line connection that had a grease zerk. I claimed that he could use his lever pump grease gun and it worked every time.
David Duffield
Old 08-02-2004, 08:14 PM
golfnow's Avatar
David Duffield
I’ve heard of this also and its supposed to work well
But I don’t know how you get the grease out when your done
Mike Minister of YEP
1986 targa 3.2 " RED"
1970 Little T (Wife’s car)
Gruppe B # 917
Old 08-03-2004, 02:45 PM
disband
juanbenae's Avatar
thats what i was thinking golf. seems like you would have a bigger problem (read mess) with the grease. i would put some liquid wrench on them and fashion an adapter for your compressor. man when i did mine the puck nearly cut my finger off as it pinned it against the other side of the caliper as it flew out. it was like an f'ing rocket, made a cool pop sound.
Old 08-03-2004, 03:19 PM
KobaltBlau's Avatar
yes, the air works well normally, but I think the issue is if the pistons are rusted to the bores, if they have been sitting for a long time unlubricated for example. This brings up the question of do you really want to reuse them if they are siezed/rusted.
Andy
Old 08-03-2004, 03:43 PM
Is it even worth taking the pistons out? I mean if the seals are still good and all is there a reason to? For sure I am going to put new dust caps on but if there is slight rust on the pistons do they need to be fixed?
73 2.0L 914
Old 08-03-2004, 05:23 PM
golfnow's Avatar
I would take them out, clean them and see if
they are still good, the chances are good that they
have rust on the pistons and it would cause them to
stick, Mine did on an 86, I don’t think the brake fluid
was ever changed out before I got it. I just rubbed them with
some paper until they where rust free also the insides
of the calipers. You don’t what to use anything too
Abrasive
Gruppe B # 917
Old 08-03-2004, 07:20 PM
Bland
unclebilly's Avatar
I got 'em out. Air at 150 psi and tapped gently on the stuck pistons with a punch and hammer. Slowly but surely they came afer liberal soaking with all sorts of chemicals. The pistons are rust free but there is a ton of crap in the bore outboard of the O-ring from shotty dust covers...
Old 08-03-2004, 08:47 PM
Alright I got one piston out, but how do you get the other one out? Air just comes out of the open space where the piston used to be. What is the best way to block this section off?
73 2.0L 914
Old 08-05-2004, 02:33 PM
Senior Member
Jdub's Avatar
You guys are NOT USING THE SEARCH BUTTON!!!!!!!!!!!!!!!!!!!!!!
This is ALL discussed: how to get one out and then the other. Search under caliper and my screen name (Jdub).
You need to block the one caliper to keep it from coming totally out, then get movement on the other.
John
'78 Targa in Minerva Blue
Old 08-05-2004, 02:39 PM
Listen to John.
This has all been documented. However, all you have to do is rebuild the side you got out, put it back in, put a clamp on the rebuilt one, and the air will get the other one out.
Penetrating oil on the piston left to soak overnight will help.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 08-05-2004, 02:54 PM
