Calling all 2.5 liter owners - how much HP?
Heading to the dyno next week with a new motor. Wanted to hear from others what kind of HP they were getting from their 2.5 liter motors? Thanks.
What else did you do?
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Not dyno'd, but PO guessed about 150 for 2.5 short stroke with Weber 40's, Solex cams, and SSI's. Not a screamer in this configuration, but fun nonetheless.
Warren Hall Student
I would think you'd be in atleast the 180HP range because you should have a higher CR and a slightly more aggressive cam not to mention the larger displacement.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
what CR does the motor have? is it the 7.5:1 that BA describes or is it more?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Formula in BA's book except 10:1 and solex cams.
I'm gonna guess right at 200 at the flywheel, maybe a little bit more
Bobby,
Good points, but I was just reciting what the PO thought. He is an experienced car guy and frequent board poster. Tyson has driven the car and we both lamented the fact that it seemed down on power. Carbs were rich and have since been rejetted and other stuff in the works. My engine is definitely not 180 HP, especially when compared to my stock SC and Carrera. Straightaway speeds are down about 10 MPH compared to the Carrera despite getting a MUCH better run off of the turns in my 73 that weighs 2100#. Let's hope RPM's motor is around 200, because he will most definitely love it. I need to work on mine......... |
PRO Motorsports
Well, the factory version made 275hp. But that's with 41mm ports and 906 cams. And of course, an 8,300rpm redline.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Did you go with a long or short stroke 2.5?
Just curious as to your results as I'm going to be building up a short stroke 2.5 (probably closer to 2.6 with the 92mm P&C's) Regards, Andrew M
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
RPM,
How did the dyno pulls go? |
Nobody
in research mode - what was the outcome RPMClassic? you left us hanging.
