She/Her
BeauBlues's Avatar
Engine Bay Question
My firewall is completly worn out on my '84 targa.
Just wondering if I should strip it off and clean up the back area or, buy a new one.
Oh yeah, will the heat from the engine mess up anything in the car if I take out the firewall?
Old 08-03-2004, 07:08 PM
Randy Webb's Avatar
defne "firewall" maybe you mean the sound pad??
Old 08-03-2004, 07:27 PM
Friend of Warren
I think he means the sound pad. Beau, it won't hurt anything to leave it off, just a bit louder in the cabin. The replacement pad is actually much lighter and better, but a ***** to install with the engine in the car.
Kurt V
Old 08-03-2004, 07:30 PM
She/Her
BeauBlues's Avatar
yeah, soundpad i sometimes call it a firewall. Anyway it's the big black padding in the back of the bay.
Old 08-03-2004, 07:33 PM
Designer King
Paulporsche's Avatar
Some guys prefer the sound with the pad missing. I think the worst thing, though, is the old, leftover glue etc that get left behind when the pad disintregrates. That stuff is tough to get off and looks bad. A new pad hides all that. When I installed mine, I left a small hole or cavity above the mixture adjusting screw opening in order to get the wrench in there more easily.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-03-2004, 07:34 PM
She/Her
BeauBlues's Avatar
So here is what i have to deal. Once again throw me your ideas
Old 08-03-2004, 08:04 PM
Sound pad
I bought the stock pad. I wish I had bought improved aftermarket one that is easier to clean and brighter.
Look around, maybe at Performance before you buy one. There are options.
Old 08-03-2004, 08:57 PM
Randy Webb's Avatar
FWIW, firewall is the steel plate that acts as a wall or barrier to any fires (also give some torsional rigidity). It sounded like you had a horrendus rust problem.
I like the new, stock sound pads. there are threads on how to install them. You might be able to do it via a partial engine drop. When you scrape the foam shreds off - be very careful to not let them get into the engine...
How do you feel about dropping the engine & tranny, cleaning everything up, doing any soon-to-be-need maint. and putting in a new sound pad? that's the issue for you to think aobut..... Good luck.
Old 08-03-2004, 09:07 PM
She/Her
BeauBlues's Avatar
I think what Ill do now is scrape the old pad off and try driving around like that. I guess if dont like the extra noise ill put a new pad in . Thanks again for the input guys.
Old 08-03-2004, 09:43 PM
