6771911esses's Avatar
Weber Settings for 2.4E
Just got this motor built. Has Webers right off a 2L 911s. What jets/chokes/venturis should I use as a baseline for a 2.4E with 2.2E pistons? Comp. ratio is probbably around 9.1-9.2:1
Mike
Old 08-05-2004, 06:18 PM
jluetjen's Avatar
I've distilled down people's carb jetting experience with 2.4's that I've collected from this BBS and other places. It will give you some ideas of what seems to work and what doesn't.
I'd also fax and then call Richard at PMO Carbs. He can answer questions like this off of the top of his head and has all of the parts that you'd need. I believe that you can also get most if not all of the parts that you need through Pelican too.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 08-06-2004, 04:39 AM
