troubleshooting blinking oil light
I am trying to troubleshoot why my oil light is blinking and was hoping someone might be able to help me.
Symptoms:
The light does not blink when the engine is at idle.
The light does not blink when the car is at low speeds/RPM.
Even at high speed/RPM, the light will stop blinking for a while, it will blink faintly and other times brightly.
The blinking begins within minutes of driving.
Checklist:
The emergency brake is fully disengaged.
The oil level has been checked on level ground, with the engine at temperature and idle.
Variables:
The oil was changed recently.
The light began blinking after being caught in a torrential summertime thunderstorm 2/3 of the way through a spirited 2 hour drive.
Battery died, had to jump car.
Have not done any electrical system checks (not sure what to check)
Car is a 72 T
Old 08-05-2004, 09:02 AM
Ground wires are probably loose or corroded or even wet from the down poor
Ben
Old 08-05-2004, 09:08 AM
Thanks.
This problem has persisted for about a week, albeit a wet week.
We'll see how things are this weekend.
Is there anything I can do to try to troubleshoot it? Would anything else be effected similarly?
Of all the things to hope a good drive on a nice sunny day will fix, a flashing oil light is hard to ignore
Old 08-05-2004, 03:08 PM
Driving member
jester911's Avatar
Eric, check to see if you have a brake light at the same time as the oil light.
If so it could bethe oil pressure sender/switch.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 08-05-2004, 04:22 PM
A 72T doesn't have an oil light
The green one at the top is the brake light, will when handbrake is on or if the pressure sender deects a problem * that's brake pressure)
The red one is the alternater chatge light
'72 911T gone
'85 TVR
Old 08-05-2004, 06:49 PM
Jeff:
I think a fair amount has happened to my '72 since '72.
What is in place now has an orange alt charge light at bottom and a red oil and e brake light at top.
I will do a thurough check on the electrical system this weekend.
Thanks for your help
Old 08-06-2004, 05:11 AM
