Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Weird hesitation...your thoughts?
Hi all,
I have a stock 79 3.0 CIS motor in my 72. Ignition system is stock, including Permatune. Right now, when the car is warmed up, if I take it above 4-5k, the engine "cuts out" like the rev limiter is stalling it or something. It appears to be ok when the motor is stone cold...this only happens when up to temp. My thoughts were to get a tune up kit (cap, rotor, etc...) and see if that fixed it. Otherwise, I was thinking maybe an MSD ignition box? Anything else I should look at?
Thanks,
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 08-14-2004, 06:27 PM
Early_S_Man's Avatar
Porsche Crest
It might work better if the Permatune was relocated to the tunnel cover between the rear footwells. Permatunes don't like heat, or so I hear about the aluminum-finish models ... and that has been confirmed on tests I did on an intermittent 3-pin model that gave considerable trouble at high temps on one 'Big Ride' ... yet Permatune returned it from tests marked 'NTF' ... No Trouble Found!'
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-14-2004, 08:25 PM
Rennch on YouTube
rennch's Avatar
Hmmm...food for thought. Thanks!
Michael O'Neal -
Old 08-14-2004, 10:24 PM
A bad set of plugs or ignition wires will make it cut out too.
Joe
Old 08-15-2004, 10:20 PM
Old Member
Mike O'Neal (emptyo)
I sent you an email concerning the bad crankshaft you sold me, can you please reply.
Clifton Brown
https://www.mancalamarketing.com
Old 08-19-2004, 12:05 PM
