-   -   how different can ignition coils be between years? (http://forums.pelicanparts.com/porsche-911-technical-forum/176639-how-different-can-ignition-coils-between-years.html)
gsxrken 08-08-2004 07:09 PM
I'd think that a coil is pretty much a coil, but there appears to be some difference since our host has them from $65 to $395 dollars for the early turbos. The blue bosch one that MSD recommends is only 35 bucks. Can anyone explain the differences?
JNadal 08-08-2004 09:32 PM
usually its just the price. If you get a different brand that costs more; then, -sometimes- you'll get a little more performance out of the coil over a stock bosch...sometimes.
gsxrken 08-09-2004 02:55 PM
bump- it's been another busy Monday:)
RoninLB 08-09-2004 02:59 PM
Re: how different can ignition coils be between years?
not as well as Warren..
Try searching Early_S_Man & coil.
emcon5 08-09-2004 03:16 PM
The windings are different. What ignition box are you running?
Tom
pwd72s 08-09-2004 05:27 PM
Re: Re: how different can ignition coils be between years?
THIS NEEDS REPEATING, because some folks don't listen the first time...;)
gsxrken 08-09-2004 06:55 PM
Thanks Ronin. I had searched on 'coil' but adding Early S Man really zeroed it in. I've got a lot of reading to do. This guy Warren is hard-core!!!
RoninLB 08-09-2004 09:46 PM
We're very lucky to have him.
Lorenfb 08-09-2004 10:40 PM
Generally, a coil is a coil is a coil!
Coils become more critical with inductive discharge ignitions vs capacitive
discharge ignitions. In both cases the turns ratio, i.e. the output voltage,
is a key parameter. If it's too high, it overstresses the wires, cap & rotor.
If it's too low, misfires will occur. The coil's inductance, i.e. the size (amount
of iron), is generally not a factor for a capacitive discharge.
Check out this web site ( www.systemsc.com ) on the Technical page under
Ignition Systems for more info.
