how different can ignition coils be between years?
I'd think that a coil is pretty much a coil, but there appears to be some difference since our host has them from $65 to $395 dollars for the early turbos. The blue bosch one that MSD recommends is only 35 bucks. Can anyone explain the differences?
Ken 1986 930 2016 R1200RS |
usually its just the price. If you get a different brand that costs more; then, -sometimes- you'll get a little more performance out of the coil over a stock bosch...sometimes.
bump- it's been another busy Monday
Re: how different can ignition coils be between years?
Try searching Early_S_Man & coil.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Hilbilly Deluxe
The windings are different. What ignition box are you running?
Tom |
Re: Re: how different can ignition coils be between years?
Thanks Ronin. I had searched on 'coil' but adding Early S Man really zeroed it in. I've got a lot of reading to do. This guy Warren is hard-core!!!
Generally, a coil is a coil is a coil!
Coils become more critical with inductive discharge ignitions vs capacitive discharge ignitions. In both cases the turns ratio, i.e. the output voltage, is a key parameter. If it's too high, it overstresses the wires, cap & rotor. If it's too low, misfires will occur. The coil's inductance, i.e. the size (amount of iron), is generally not a factor for a capacitive discharge. Check out this web site ( www.systemsc.com ) on the Technical page under Ignition Systems for more info.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
