I have an 87 carrera coupe with 120,000 miles I have just done a engine rebuild.New pistons,rings,liners,a valve job, new cam shafts and a new clutch while I was at it. I am about 600 miles into the break in period and something new has popped up . Between 2800-3000 rpm the car starts bucking,I am not hard on the throttle just driving along,this will happen in any gear,when you accelarate it goes away.
I have checked the coil, not it , i have tryed the 02 sensor does not change,the throttle position switch,I have even swapped out the airflow meter,and nothing has worked. Anybody have some good ideas,because right now I am scratching my head. Thanks Sean |
Diss Member
Had the same problem with my 87. It would buck hard enough to just about take your head off. Sometimes it would go away for a bit but it made me scared to stand on it. Everyone looked at it with no luck.
In a fit of frustration I decided to drop the engine and while disconnecting the plug for the injector harness I discovered that it was floppy loose. Turns out that normal vibration would bounce it up and down and when it started to buck it would bounce up and down. I strapped it down with a nylon tie strap. Has worked perfectly since then. I would check that connector which is in the very front of the engine compartment, in front of the heater blower, right next to the driver's side shock. If there is any looseness to the connection it could be the problem. If that isn't it I would check every electrical connection in the engine compartment starting with the ground on the intake manifold and the transmission grounding strap. Good luck... Wayne
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
OK Sean, I told you these guys are good.
Joehand1
1987 Porsche 911 Carrera Targa 2006 Ford GT-Tungsten 2017 BMW M240i 1965 Porsche 912 2018 Mercedes AMG GLE 43 |
I'm having a similar problem w/ my 88, it idles, runs, but under acceleation at 4100 rpms or there about in any gear, it just gets real rough and stops accelerating, it's not a bucking, but more like it's running out of gas or getting a poorly timed spark. I've checked the fuel pressure, replaced the main relay, plugs, wires, cap, rotor, fuel filter, the 02 sensor and checked grounds... no fix, not sure what to so next... Could you let me know what you find out via this post??? I will post an answer from Stephen Kaspar - PCA WebSite
Coz 88 911 72 914-6 Vintage Racer 76 914-6 Vintage Racer |
Imcoz's answer from Stephen Kaspar - when I posted a similar problem on the PCA WebSite - I might suggest that you check the injectors. As these cars continue to get older I see more and more issues with the injectors and the harness. On several
occasions the tips have fallen off or the injector has simply failed. If either happens the pattern will cause fouling or inconsistent burn on that cylinder. I have also seen the main injection harness with shorts which in turn will dump the injector and foul the plug. Have you taken a reading of the plugs? Is there a cylinder that is richer or leaner than the others? How about bank to bank? If you have a cylinder than is fouling over the others check the injector. If you have a bank check the harness. There can be other things that will cause issues such as the HTS or even the coil. You could also have a failing ref sensor. All of which have a procedure for checking. I would start by looking at the plugs. One thing that might help to be more accurate in the plug viewing is cut a plug at that RPM. In other words if you are at WOT and at 4k RPM shut the car off right in the middle of it and pull to the side. Pull the plugs and check them right there on the spot. The reason you do this is as idle the car may be fine and give a false reading. At 4K where the issue occurs this is an accurate way of looking inside the motor so to speak. Stephen Kaspar - PCA WebSite
Thanks or all the info,I wil look into these areas .
The one thing, this is happening at lower rpm just driving along light on the gas . it is not as violent as Wayne stated,and you can make it go away by raising the rpm, but I'm going to look into the injectors and harness I will let you all know as soon as something happens Sean |
Go Speedracer, go!
You might check for moisture inside the distributor cap. I have had that cause this same problem with a Carrera. It's a long shot, but worth a look.
1981 SC ROW Coupe |
I will have a look in the distributor
thanks for the idea |
hang a new cylinder head temp sensor and DME relay on it before you spend a lot of time on it.
)I would try the Cylinder Head Temp sensor as he suggests. theres not much left that you didn't try. Eddie
Basically, I'm One Giant Train Wreck. http://community.webshots.com/user/evill914 |
John
Thank you for the info, I will give that a try and thanks to all the other suggestions.I will post the results soon Thanks to all Sean |
Diss Member
A really violent bucking would normally be electrical because that is the only way you can turn it on and off that quickly, so general electrical is probably out. Less violent; I would still look at engine grounding straps (it's free to look!) but it would make me think of sensors or fuel. The injectors seem to be an obvious place to look except I would expect an injector problem to get worse as the RPMs rise. It probably isn't ignition. A spark gap has a lower resistance in a vacuum which invariably means that the higher the throttle position-> the higher the cylinder pressure-> the harder it is for the spark to jump. In the sensor dept... Has your car ever had the cylinder temp sensor replaced? It is a notorious problem on the early Motronic cars as pointed out by John Walker suggestion to start there. BTW it is easy to remove the old sensor by clipping the wire off but it requires a special socket to put the new one in. To make your own just get a deep socket and grind a slot all the way up one side of it so the wire can hang out. Wouldn’t of thought of the DME relay but you should always keep a spare in the car anyway and it is easy to get at, under the drivers seat. I would also check the Oxy sensor connection. If it was intermittant it could vary the fuel quite a bit. Wayne |
Wayne
I will be sending some time in the engine compartment thanks for all the ideas Sean |
Irrationally exuberant
If you fill out your profile so people know where you live someone might volunteer to come and help you.
I would check that the head temp connector is secure. Its not enough to push on one of the connectors, you need to squeeze both sides of the connector to make sure it is seated. You'll probably want to remove the plastic heater tube that's in the way to do this. The head temp connector is on the left side of the engine compartment below and to the left of the heater blower. There are 3 connectors in the same bracket. The head temp connector is the white one. I believe the old sensors use the engine for ground and the new ones have their own ground wire. The new sensors have a very white wire sheath and they take a 14mm socket. The old ones take a 13mm socket I believe. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris
Thanks for idea.I'm about to get to work and see what I can come up with Sean |
It's most likely the air flow meter (or flapperbox, barndoor, what ever you wanna call it)
The switch on it is probably worn out This is because the RPMs at which the problem occurs are the RPMs at which the car is (or was) most driven, so the switch/contact sees most wear at that position Check the contacts of the switch and see if you can clean it up or replace the whole unit with a new, used or rebuild one cheers, Jeroen
WWW.9GEAR.NL |
Jeroen
I already tried a replacement airflow meter it was not the problem. But I think I have found the cure,I went over the three sensors on the flywheel,cleaned or replaced the connectors ,and now it is as smoth as silk at 2800 rpm and as nice through the power band,I can't wait for the break in period to be over so i can go up to the red line Thank you all for your input ,there were many good ideas Sean |
