-   -   Checklist for reducing heat in hot-running engine. (http://forums.pelicanparts.com/porsche-911-technical-forum/176903-checklist-reducing-heat-hot-running-engine.html)
Jdub 08-10-2004 08:29 AM
Can we stand another "my engine is running too hot" thread?
You guys scared me with posts about running an SC with the temp needle sitting at the 9 0'clock position. This appears to be equiv. to about 220degreesF. Without direct temp. numbers on my SC's "white-none-red" gauge I had always figured I was OK at mid-point.
So, what can be done to reduce the engine heat? Being an SC, I *believe* I have the better fan ratio (tell me if I'm wrong) I thought I would attempt to start a list of fixes. Tell me/add your thoughts if you would.
Cheap:
= Remove all dirt etc. from trombone, lines, and oil tank.
= Check for foreign matter in engine finning, etc. (Can you safely jet-spray from the bottom of the engine at a car wash?)
= Check CO2 (I run at 3.5% per JohnW's advice)
= Check timing
= Remove side rocker to expose/cool lines
Less Cheap:
= Swap the dino oil for synthetic (do you flush system by running synth for 50 miles then dumping it, plus old dino.?)
= Upgrade to Carrera/Mocal with fan
= Alter air access in some way to direct air to trombone cooler. How to do this?
= Swap in thermostat that opens sooner? Available?
Many thanks for your thoughts. At the mid-80's in temp., I can get my oil temp. needle just a tad north of horizontal.
John
Chuck Moreland 08-10-2004 08:49 AM
John, Those are mostly good thoughts.
I wouldn't bother removing the rocker cover. It is open enough that plenty of air flows though it.
If you change to synthetic oil, a 50 mile flush isn't necessary.
Trombone won't respond well to inceased airflow. The Carrera cooler will.
You wouldn't want a lower temp thermostat. The tstat is fully open by 210. Above that temp your cooling system is maxed out and not regulated by the tstat. Having that tstat open lower wouldn't help.
For even more cooling capacity you could add a center mount oil cooler and or finned oil lines.
ubiquity0 08-10-2004 08:53 AM
Before doing anything have you verified that your gauge & sender are accurate? It may be a non-issue.
Jim Richards 08-10-2004 08:55 AM
This is a great checklist. Grady's suggestion about fan ratio is one to add to the checklist. Also, for cars older than 1977 (?), I think the air deflectors will need to be modified to the later design (remove some metal) to get better airflow.
barlowdo 08-10-2004 09:01 AM
One of the more recent Panorama issues had a pretty good article on cooling 911's. It mentioned something about how the numbers are still on the temp gauge but that you have to look at it at an angle to see the numbers. This was news to me.
-Don B
mtelliott 08-10-2004 09:30 AM
In the heating industry, they use something call fin tubes for baseboard radiant heaters. It's a small aluminum fin that wraps around the copper tube to help radiate the heat. I always wondered if adding fins to the trombone heater would be a cheap alternative for helping the efficiency of the trombone cooler.
MAS 08-10-2004 09:37 AM
Mid point on my 77 911S gauge (marked in celcius) is exactly 100C, or 212F.
-MAS
Emission 08-10-2004 10:01 AM
Switching to synthetic won't lower temps in itself. It will however, give your engine added protection at high temps.
My best "upgrade" oil cooling was blocking off the air spilling under the cooler and forcing it through the cooler. I also pulled my front fog.
fireant911 08-10-2004 10:50 AM
I too was having concerns about my oil temperature due to these hot Alabama summers. After examining my oil lines I felt that there was just too many 'mashed' areas through none were flattened more than 50%. This provided a good opportunity to perform two projects that I have been wanting to do: install Elephant Racing's finned oil lines and install a 28-tube cooler. My choosing this type cooler over the other coolers was based on the repeated recommendation in Bruce Anderson's book which made very good logical sense. I realized 10° F reduction in temperature just by the addition of the finned oil lines and and overall reduction of 25° F by the addition of both the finned oil lines and the 28-tube cooler. I am maintaining about 185° F when the outside temp is 90° F which I think is quite a success.
If you are in the market for this type cooler, there currently is one on Ebay (no affiliation I just look since these are tough to find coolers):
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7914949999&catego ry=46095
Grady Clay 08-10-2004 11:13 AM
Contrary to the adage “Never say never.” I’ll go out on a limb and contend that no 911SC had both 1.81:1 fan ratio and the 245 mm 11-blade fan simultaneously.
The ’78 & ’79 911SC had 1.81:1 ratio but the 226 mm 11-blade fan. The ’80 and later had the 245 mm fan but the pulley ratio reduced to 1.68:1.
Please correct me if I’m mistaken.
Regardless, the combination of 1.81:1 ratio and the 245 mm 11-blade fan is probably the best you can get with stock 911 parts.
There has been some discussion of a fan pulley size of 80 mm as opposed to the published 84 mm fan pulley diameter. Who can shed some light on that? What years, models, part numbers? If there are standard Porsche parts available with an even smaller fan pulley the overall ratio might be 1.9:1.
On one of the former threads we discussed custom crank pulley larger diameters and modifying the engine mount to fit.
I will reiterate what I have said several times. The best way to address high temperatures in an air cooled 911 is to pump more mass air flow across the head and cylinder cooling fins.
With the “mild cam” engines (T & CIS) we are tempted to drive in the 2-3000 RPM range. With high temperatures, you should buzz along at 4-5000+ instead. It is RPM that pumps the air. There is the added benefit that the A/C condenser dissipates more heat with higher air flow (fan ratio & RPM.)
Jim is possibly correct about the cylinder baffles. One consideration about this heat exchanger (HE = cylinder and head fins) is that there is greater heat transfer from the HE to the air with greater pressure drop across the HE. The other side of the equation is that with greater pressure drop there is less mass air flow. Every HE has an ideal pressure drop–to-air flow ratio. That is why some with small cross section area and very thick are designed for high pressure drop and others with large cross section area and thin (like most automotive radiators) are designed for large air flow and minimal pressure drop. I don’t know what that ratio is for a 911 but I’ll bet it’s not far from stock.
Years ago, I considered “cross drilling” 911 head and cylinder fins and press-fitting tubes or rods of copper/brass/aluminum in order to increase the total surface area of the HE. I settled in on the fan ratio and the “Rubbermaid Solution” as the most effective and least cost.
Best,
Grady
82SC 08-10-2004 12:18 PM
haha I love how chuck is always willing to give advice but never touts his products...so I will
go to ELEPHANT RACING
finned oil lines, carrera coolers with larger ports...
Jdub 08-10-2004 12:27 PM
I should add to the list that using a bra on the car will prevent air from going through the slit between the valance and bumper.
Since my car came without foglights ('78 SC Targa) I may put some louvres vents into the passenger side. On the reverse side, a bit of ducting to direct the air to the trombone.
This short of going to a Carrera/Mocal. We just rarely see the hot weather up here so this is a concern only about five or so days of the year. Otherwise the temps are perfect for the Porsche engine.
John
Randy Webb 08-10-2004 12:33 PM
Slight change in topic -- what do people think of the Earl's coolers?
Is it worth taking the one off my car that the PO put on and going with a Carrera cooler?
Wil Ferch 08-10-2004 01:14 PM
I believe Grady clay is correct as to the offered pulley sizes and fan sizes. I don't think there is a combo of 245 mm and 1.8:1
I've found that 1.67:1 ...and 1.8:1 is really not that different, and is more influenced by the number of pulley shims you use between the pulley halves to get the belt tight. Prety close.
Yeah...Porsche used 80, 83 and 95 mm fan pulleys. Why they even bothered between 80 and 83 is beyond me. Just causes problems.
---Wil
Grady Clay 08-10-2004 02:27 PM
I agree with Wil, the ratio is influenced by the variable (uncertain?) diameter of the fan pulley. What I have been quoting is the Factory specified numbers that Porsche actually published. If you just use the various diameters, you get all sorts of peculiar ratios.
I would be interested to see if someone has put counters on the fan and crank pulley and determined the actual ratios with various components.
Wil, could the difference between 80 mm and 84 mm on the fan pulley be just the difference between a measured dimension and the Porsche specified number? If there is a part with smaller-than-84 mm diameter, that would be great.
An interesting exercise might be to make several slightly different 134+ mm diameter crank pulleys and run the fan pulley with all six shims (7+?) between the pulley halves to minimize the fan pulley diameter. The limiting factor is the inside of the fan belt can’t touch the pulley shims. You can make a single shim of proper dimension so you don’t have to deal with PIA multi-shims getting out of place.
Interesting, Porsche took this issue so seriously in ‘80 they published this:
“NOTE: Only the approved belt form Goodyear, Part No. 999.192.176.50 may be used.
The new belt must be tightened more than previously.
Adjustment: Tighten belt as usual (10 to 15 mm deflection). Then reduce the number of spacers between the pulley halves by one (ca. 5 mm belt deflection).”
I think this was to keep the small (84 mm) diameter fan pulley from slipping.
Another issue here is it appears we are close to the limits of fan belts. Clearly a new belt should be run-in and then readjusted. I took racing run-in belts with known number of shims.
Something as simple as pulleys, fan belts, and fans can have a profound effect on a 911 engine.
Best,
Grady
Paulporsche 08-10-2004 02:47 PM
JDUB,
When do you get the 220 degree temps? What type of driving? Do the temps go down when you have air moving past the cooler, but go up when sitting in traffic? Remember 220 isn't too hot under these types of conditions, and you want to get your temps high enough to burn off that "cheese" or "mayo" like substance that some find in their oil because their temps are consistently too low.
If you haven't searched yet, you can find lots of suggestions on various ducts and vents peaole have come up with to add air flow. Some are very inexpensive.
Finally, make sure youe CO and timing are right. If you are running too advanced or too lean, then temps will go up.
kach22i 08-10-2004 05:13 PM
What is the "Rubbermaid Solution"?
Never mind, I found it:
http://forums.pelicanparts.com/showthread.php?s=&threadid=150982&highlight=Rubber maid+Solution
kach22i 08-10-2004 05:22 PM
I think mine are black, perhaps coated......are they supposed to be bare bronze/copper?
I had an idea, that I have not worked through yet; bolting a perforated brass plate between the trombone opening. The connection points or clamps would have to transfer heat to the plate, I am not sure it will work. I would not want to soder or braze anything until I had some clue as to it's effectiveness.
ChrisBennet 08-10-2004 06:24 PM
Is the any chance the mixture is off making it run hot?
-Chris
911pcars 08-10-2004 07:48 PM
The problem with the trombone cooler is insufficient surface area. If you braze fins onto the tubes or lengthen the coil, it will dissipate more heat, but it still won't be as efficient as a properly engineered oil cooler.
Sherwood
pgsandiego 08-10-2004 10:15 PM
I added a euro premuffler in place of the cat in an attempt to run a bit cooler (less exhaust restriction). It seems to run about 10 degrees cooler. Not huge, but every little bit counts.
Too bad about the synthetic oil. I thought Id read it helps cool a bit and was on my "to do" list. I guess now I'll wait until the next scheduled oil change...
Patrick
RoninLB 08-10-2004 11:19 PM
ditto..
180deg oil temps are nice. Actually I usually run a bit less than 180 except on 90+deg/3.5k+ in 5th gear days.
Does anyone know what the max CHT's are Designed by PAG into our cars? I'm speculating around 350deg?
RoninLB 08-10-2004 11:25 PM
Hi Jim..
I had to snip my deflectors. I'm not sure if it's directed at only CHT or + small oil temp drop. CHT control is very important imo.
RoninLB 08-10-2004 11:50 PM
I figure you have this already. I don't have the dia's
http://forums.pelicanparts.com/uploa...1092207037.jpg
fireant911 08-11-2004 04:33 AM
pgsandiego,
I would not be too hasty about dismissing the ability of synthetics in reducing the oil temperature. Reducing friction will in turn reduce temperatures which is one of the advantages of synthetics. I would visit Mobil 1's web site and do some informative reading about the subject and make my own decision first. My car(s) responds extremely well to Mobil 1 - not everyone here agrees but it is certainly worth looking into. My daily driver gets 3-4 extra miles per gallon when synthetic is used (I have been keeping records since I purchased the car in 1995) and it is my belief that this can be attributed to the added lubricating properties offered by synthetics. The Porsche leaks no more with synthetic than with conventional oil.
Bill Verburg 08-11-2004 05:17 AM
For those that don't know, the tin mod was incorporated in all 911 and 930 engines built from March '77 on. Earlier engines should have this done.
http://forums.pelicanparts.com/uploa...1092226404.jpg
http://forums.pelicanparts.com/uploa...1092226420.jpg
I also recommend the '76 -'77 pulley w/ '84- fan. This will give the large ratio and the fan has additional cooling slots for the alternator.
Of course a nice big cooler never hurts. Best power will come from keeping temps in the 180&degF - 210&degF range, some like it hotter to boil off condensates, but they do boil off at lower temps, it just takes a bit longer.
Grady Clay 08-11-2004 07:26 AM
I agree with Bill V. There is great advantage to the thermostatically controlled oil systems. On 911s with the front cooler there are two independent thermostatically controlled coolers – one at the engine and the other in front. Both operate in the 180-210F range. The issue is the coolers are not of sufficient size and air flow to dissipate the necessary heat. Consequently the temperature rises into the 275F+ range in order to dissipate that heat.
As Bill points out, it is very important to get the engine to operating temperature to boil out the contaminants (mostly gasoline & water.)
Changing the fan arrangement dissipates the heat not via the oil system. It’s too bad Porsche didn’t develop a thermostatically controlled, variable ratio engine fan. The technology certainly exists.
Yes the ’84- fan with alternator cooling slots is desirable (necessary) for the larger capacity alternators. This brings up another issue when fitting the 245 mm fan to SCs originally fitted with the 226 mm fan (’78-’79) – you must also change the fan housing. All fan housings are not equal. Starting in the late ‘70s, the housings were machined progressively deeper to accommodate the larger alternators. You need to have the correct fan housing to match your alternator.
Best,
Grady
barlowdo 08-11-2004 07:32 AM
"I think mine are black, perhaps coated......are they supposed to be bare bronze/copper?"
I think you want to keep them black to act as a "Black body radiator"- to draw the heat away from the oil. And remember- correct me if I am wrong -but I believe oil does not transfer heat as efficiently as water.
-Don B
kach22i 08-11-2004 08:39 AM
Sherwood
There is the right way, then there is the "let's try this and be different" way. I have paid that price too many times.;)
kach22i 08-11-2004 08:48 AM
Originally posted by fireant911
pgsandiego,
I think synthetics in an old car is pure evil. However it does flow better, right out of the seals sometimes.:D
I believe the oil designed for high miliage cars will make the car run hotter, and synthetic will make it run cooler...........but that's just my theory.
I did try a tank full of regular gas once, I swear it ran 5-10 degrees F. cooler, but also had a bit less power.
Nothing like a cool day or a little rain to cool things down.:)
JMPRO 08-11-2004 09:04 AM
How about an electric driven fan. The motor could be hooked up to a transducer the is controlled by motor rpm like a tach.The controll could be adjustable to overdrive the fan or even a delay to slow the fan behind the rpm of the motor for additional cool down . You might even free up a couple of hp with the system.
Jerry
Jdub 08-11-2004 09:21 AM
Well here are results of my "research" yesterday. I drove to a bicycle race about 50minutes away. Going down, ambient temp is 86degrees. Car oil temp gauge comes up to 9o'clock exactly and moves slighty up from this only when I rev the car higher: shift down to fourth, or third, and get some speed. Funny thing: stop and go, the temp drops back down to horizontal. Revs seem to increase the temp. I had Grady's advice in mind and was trying to stay same road speed/higher revs. Seems to raise the temp on my car.
Going back later in the evening, has cooled off to upper 70's. Same temp all around, same results in rev testing.
Seems my car likes that temp. I think that the engineers at Porsche must have used my car, my area to create that gauge cause if you didn't know any better, you'd think the car was operating at perfect operating temp.
I am off to put a Carrera oil cooler in and switch to synthetic. I won't play this game.
Anyone have a clean Carrera cooler for sale?
John
wente 08-11-2004 10:06 AM
another checklist item
No one has mentioned this, but cleaning your engine mounted oil cooler should be on the checklist. I recently cleaned my 87' engine cooler and achieved about a 15 degree drop in oil temp. I didn't do an engine drop or
anything that involved, just pulled the fan/alternator. Scrubbed the cylinder fins with a brush, then attached a small tube to the end of a can of brake cleaner and stuck it down the air scoop to the engine oil cooler. Sprayed a bunch in there, waited, put the garden hose in the scoop and watched flakes of greasy crud come out of the cooler. I repeated that several times, and also used some simple green. worked like a charm! We have cottonwood trees here, so I was always suspicious that my cooler may have become clogged up with fuzz on top over the years....
Ellsworth
Randy Webb 08-11-2004 10:18 AM
Yes, it's a good idea to clean the outside of the engine-mounted cooler, all the cylinder fins, and any remote coolers.
Grady Clay 08-11-2004 11:15 AM
Ellsworth,
Welcome to Pelican. Great recommendation.
For those more adventuresome, it is also easy to remove the engine oil cooler with the engine in the car.
What was the condition of your cylinder fins? It is a reasonable assumption that your head fins are similar.
Best,
Grady
Jdub 08-11-2004 02:01 PM
How easy is it to remove that engine-mounted oil cooler? I'd guess that would be something to do during a valve job/oil change.
Am I looking at removing fine-thread oil hose that might be stuck in place? That is a bit of a nightmare!
John
Grady Clay 08-11-2004 02:46 PM
John,
Good point. The ’66-’71 911s have a thread fitting hose to carry oil from the sump to the intake of the pressure pump via the large aluminum tube that is below the cooler and part of the structure. That fitting may be very old, some were steel on aluminum and others were aluminum on aluminum. Great care should be exercised when attempting to detach these fittings. Undoing this fitting is necessary for engine removal so you should maintain it in good condition. Often the fitting is seized at the cooler and mechanics will disconnect the oil hose at the tank.
So long as you can get one end disconnected, the oil cooler removal is relatively easy. Everything else is just tin removal (usually three pieces.) You will want to have new case-to-cooler seals (3).
Best,
Grady
wente 08-11-2004 04:33 PM
Am I correct in the assumption that the engine mounted cooler on my 87' carrerra requires a partial engine drop to get to the top bolt? I chose to not remove it and go the route of just cleaning it... Isn't it true that it's easier to get the cooler off the older 70's cars?
I picked up a set of the o-ring seals and I plan to take cooler off the next time I go in deep for a valve adjust/oil change. Figure it has 130k on it, probably could use a good internal cleaning.
Grady, thanks for the welcome... been lurking here for years and living over at rennlist, just never got around to registering! My cylinder fins were actually very clean, just gave them a quick brush while I was in there. The oil cooler had some stuff in it, and had a good greasy coating on the underside from a P/O oil leak.
Ellsworth
ga_mueller 08-11-2004 04:54 PM
I pulled and cleaned the engine oil cooler on my Carrera a couple of months ago without partially or fully dropping my engine. Bentleys has a fine set of instructions. It took about 4 hours, and it was incredibly filthy. Now I can tell that I really DID fix all those oil leaks from the back of the motor!
Grady Clay 08-11-2004 05:06 PM
ga,
Can you post a step-by-step for wente and others. You can do it far better than I can.
Did you do anything other than cooler to address oil leaks at the flywheel end of the engine?
Best,
Grady
