-   -   I FAILED the TEST ONLY smog check! (http://forums.pelicanparts.com/porsche-911-technical-forum/176966-i-failed-test-only-smog-check.html)
beepbeep 08-10-2004 04:28 PM
Pouring some E85 will effectivly lean out the mixture as E85 has stochiometric mix of 9:1 instead of 14.7:1 for ordinary gasoline. It also produces less CO.
Unfortunatly, too lean mixture will produce more NOx beacuse of hotter combustion.
911Velocity 08-10-2004 07:53 PM
Whenever I used the alcohol trick the NOx dropped like a stone.
vash 08-10-2004 09:34 PM
i may have missed it, what type of alcohol?
and sorry emission, you will nail it tomorrow. all of us, 80's cars are pulling for you. we are in this friggen hell together.
Emission 08-10-2004 10:24 PM
Originally posted by tobluforu
"...but you would be surprised at how much these little things affect emissions, emission."
The irony of my screenname. :(
Where do I find this E85 alcohol? How many gallons can I put in (what mixture)?
RoninLB 08-10-2004 10:27 PM
sorry that I'm no more help on this smog game.. best of luck.
Emission 08-10-2004 10:39 PM
Bite your tongue! You were first to suggest installing a plugged injector... this may be the solution if I fail tomorrow.
Wayne 962 08-11-2004 12:57 AM
Originally posted by john walker's workshop
why not run the 25mph test in first like you would drive on the street? the high gearing of that trans messes up the test results. smaller diameter tires would also raise the rpms at 25mph and probably result in a lower CO.
The problem is, you have to run at a certain speed, within a certain RPM range...
-Wayne
Wayne 962 08-11-2004 12:59 AM
Originally posted by stlrj
So you're a bit rich. What's the big deal? Just lean it out, pass the retest and get on with your life.
Good luck.
Yes, what he said. Just lean the mixture out, and you'll pass no problem! Happens all the time on the SCs. The CO is the easiest thing to control on the CIS cars. When you get to Motronic, it becomes a bit more difficult...
-Wayne
sammyg2 08-11-2004 08:33 AM
Mine failed the rolling check on CO last november at a test-only station. I leaned it out, played with it, even had a local shop set the CO.
No real progress until I replaced my O2 sensor. Seems it was reacting too slowly causing swings in the mixture. After replacing the sensor it passed easily.
banjomike 08-11-2004 08:38 AM
Lean it out a bit. I believe that using lower octane gas can make some difference. I went through three tests recently to get passed. The first I was using regular unleaded, and I got the best numbers of any of the three tests. The other two tests I had mid grade gas and failed once and squeeked by the second time.
avendlerdp 08-11-2004 08:43 AM
Hey! How old is the O2 sensor?? If it's not in new condition the car will make more smog. Particularly at low rpm under small loads. Unless it's less than a year old get a new one. They "slow down" over time and even when they are still "working" you may get an improvement with a new one. My 560 Benz had this issue (CIS as well) and a new O2 sensor fixed it fast.
Alex
Joe Bob 08-11-2004 09:15 AM
Dude.....reach in and disconnect the middle fuel injector on one side......everything falls like a stone.
TedSlick 08-11-2004 09:26 AM
I just posted about my similar problem...Test Only CA smog fail yesterday. We've definitely been targeted. All my cars at this point must see the Test Only guy every two years :(
Don't feel bad, Emission, my CO result was not even close to passing.
Can any details be given regarding MikeZ's suggestion to disconnect a fuel injector? How is it done?
Good Luck. That car deserves to be driven :)
Emission 08-11-2004 09:51 AM
I just got back. FAILED it twice again today (he ran the test two different times, trying some different things).
AAAAWWWRRRGGG!!!!
I'm going to lean my mixture, then try it again early next week. I'd also like to try to run some E85 if I can find it!
TedSlick 08-11-2004 10:02 AM
Curious. Is one of the things you tried disconnect a fuel injector?
I think I'll be checking my connections then trying to locate the E85 stuff myself.
Are the re-tests typically free...or $50 ea time? :eek:
Joe Bob 08-11-2004 10:09 AM
E.....
Come up this weekend and we can put it on the analyzer....
avendlerdp 08-11-2004 10:33 AM
Is there no oxygen sensor on that model of 930? I tell ya, it's cheap to change and may do the trick. Unless yours is new I'd go there. If it's a single wire use the Bosch generic. If it's a four wire, use one from a Mustang 5.0 and splice the wires. If your car passed ever in it's life, why should you have to do some hokey "Mad Max Beyond Thunderdome" fix now when Autozone has your part!! Buy the special socket tool while you are there and make the job super easy.
Keep us posted.
Alex
pbs911 08-11-2004 10:36 AM
I hope he is running these tests as a pretest. Any failed tests are registered with the DMV as the system is hooked up to their computers.
Get a CO meter and lean it out. I did on my 3.0 motor and it ran like cr@p, but it passed. After the test I drove around the corner and cranked open the CIS.
Emission 08-11-2004 11:20 AM
The O2 sensor is brand-new (3-wire, I think). Maybe 100 miles on it. I put it in just the other day.
The first test was $39 (with coupon). Subsequent tests have been free - thank goodness (though had I passed, it would have gladly parted with a little extra cash... ;)).
All of these tests are registering with the DMV. It doesn't hurt me as far as I can tell.
I think I'll contact MikeZ about bringing it up...
dvkk 08-11-2004 11:40 AM
What are all the other numbers like? If they are near the limits but just under, I would suspect the CAT is on its 9th life. How many miles on the car? Is it the original CAT?
