Help! Fuse For Stop/reverse/turn?
hey guys, i have a 74 911 coupe.
does anyone know how many amps the fuse is supposed to have thats handles the stop lights turn signals and reverse lights on the 74 fuse box cover it shows one fuse handles all 3 of the above. does anyone one the amps this fuse is supposed to be? 8-16-25? need help, thanks guys! |
bump
Have you checked the electrical diagram our host has posted? http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
Seems like in mine ('86), the wiring's a bit different, so the fact that my turn signals are on left and right 5A fuses (I think) wouldn't help you much. Dan |
Also not much help, but here are the pages from my 82 manual for the fuse and relay blocks:
http://forums.pelicanparts.com/uploa...1092327089.jpg http://forums.pelicanparts.com/uploa...1092327101.jpg Tom |
hey tom,
thanks for the diagram, i need that for a 74 coupe. that shows the correct amps for the fuses.... CAN ANYONE ELSE POST WHAT TOM POSTED FOR A 74 911 COUPE? thanks guys,............ |
not for a 74, but here's what I have in fuse box I -
# amp function 1 8 interior 2 16 warning light 3 40/25 window opener 4 16 cig / aux heater 5 16 sunshine roof / rear window wiper 6 40/25 windshield washer 7 40/25 fresh air blower / heated rear window 8 15 stop/turn signal/backup 9 5 blinker front left 10 5 blinker front right AutoZone doesn't carry any 5 amp in the GBC fuses - where do people get these? Also, what is a "40/25" - 90% of my fuses appear to be original. |
Re: Help! Fuse For Stop/reverse/turn?
stop lights / reverse lights, fuse # 11, 16a front indicator left, fuse # 10, 5a front indicator right, fuse # 9, 5a Hope that helps. ( I just re-did all the wiring in the front end after the previous owner shorted & melted a few & this is how I set my fuse box up afterwards.) -John |
fuses
this is what i needed,.... THANKS SO MUCH GUYS!
came through again,..... now at least i know the amps!!!!!! |
| All times are GMT -8. The time now is 06:53 PM. |
