PRO Motorsports
Hey, that's my work! So obviously I recommend option "B".,
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
The mounts don't tear away from the body, they tend to tear where they meet the body or at the bend. By doing the pictured support, it reduces flex of the mount such that the metal doesn't fatigue and tear.
Nice welds Tyson!
Chuck Moreland - elephantracing.com - vonnen.com |
Interesting. Mine tore here(See picture).
James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
Hilbilly Deluxe
This is something I have been meaning to do, as I have late Carrera sways. Tom |
PRO Motorsports
Yes, but not as beefy. James, your's tore there because the mount flexed. They are only attached on one side, so the force cantilevers it until it cracks or tears out. I've also seen the nuts pull out, which is why I weld the reinforcements to the nuts as well.
Tyson,
I know...I had to do a quick repair at one point and it seemed to hold for a while. As you said, it flexes and that area ends up being a stress riser. It was one of those dilemma's" if it's not broken, don't mess with it". Well, it finally caught up to me at The Glen. Pretty sure hitting the curbs in the bus stop did it. I already had the Smart ones in my toolbox anticipating the day. I thought about making these but Smart already does a good job. Cheers, James
I went with style "A" a few years ago after my original ones got ripped off. I then reinforced the metal the bolts go through. I have had several component of my SRB's break, but the mounts have held solid. The joint where the mount is welded to the frame is where mine broke. I can't see option "B" doing anything to help this weak point other then thickening the weld. I used 1/8 steel the was cut to follow the torsion tube and the fit flush with the mount. It is now triangulated for strength and less prone to flexing. I wish I could take credit for the welding, but I have a great body guy. Last edited by 89911; 08-12-2004 at 06:31 PM.. |
Sorry to rehash an old post.
Is there a consensus on what size rear bar results in mount fatigue? From what I have read, it seems that anything beyond 22mm will result in problems? I have a wimpy three position 18mm rear and have never had issues, but I need a bigger rear bar. James, What size rear bar are you running? Thanks. Tinker |
Hey Tinker, I'm running a 27mm rear bar which is pretty big by most standards. This is on a Club Racing car so my experience is really worst case scenario. My problem was exposed at WGI where I was hitting some curbs through the bus stop which is very hard on cars. If you have any further questions please let me know.
Cheers, James
IMO, the sway bar mounts fail most often when swaybars are upgraded without upgrading torsion bars on the street. Track tires will also contribute more to ripping the mounts from the body.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
I'm running 31mm torsion bars with 27mm ARB's . Once a car reaches this level of development the factory mounts can't handle it. They end up being the weakest link. At least this was my experience.
Cheers, James
Actually both of my original unreinforced mounts failed. I have stock T-bars and stock anti-roll bars on a 1976. Even with the lower loads generated by the smaller bars, the repeated loading will cause metal fatigue, and they will fail someday. Of course I've done my share of flexing those anti-roll bars .
Mike Searching for a new ride '04 VW GTI 1.8T RIP ![]() '76 911S 3.0 RIP ![]() http://www.pelicanparts.com/gallery/BanjoMike |
