AZ1977911's Avatar
Porsche Crest Wiring on elwctric window switches
Hi All,
Well I goofed! Removed door panels last night. It was late and my digital camera wasnt working, so I didnt take pictures of the wiring on the electric window switches. Went to put the switches back on and found I had forgotten the wiring sequence. Now the switches dont work. 1977 Carrera3.0 Targa, w/ pass/driver switch on drivers side and switch on pass side...
If anyone has pics or can tell me the sequence, I'd be very appreciative.
Thanks in Advance,
Greg
Old 08-08-2004, 02:18 PM
AZ1977911's Avatar
I think I found a thread that will help! (just had to keep searching!)
Window color wiring scheme for 86?
Its for an 81, I think its the same for my 77 3.0
I'll post how it worked out...
Old 08-08-2004, 04:02 PM
As per workshop manual, each terminal is numbered 1-5, and terminal/wire color is as follows:
switch, on drivers side, for passenger side - 1/redwhite, 2/redblack, 3/red(doesn't matter which red), 4/brown, 5/red
switch, on drivers side, for drivers side - 1/black, 2/green, 3/red, 4/brown, 5/red
switch, on passenger side - 1/black, 2/green, 3/redwhite, 4/brown, 5/redblack
Hope this helps.BTDT
'56, '59 356A Coupes
'67, '68 912 Coupes all gone
'72 911T coupe
Old 08-08-2004, 04:09 PM
After checking the pelican thread, I checked the manual for an 81 and the wire colors are as in my previous post. Don't know where all those other pretty colors come from, but they aren't in the factory wiring diagram for 81. Post how it goes. Good luck
'72 911T coupe
Old 08-08-2004, 04:16 PM
AZ1977911's Avatar
Thanks Mike!
Windows working! Mike your wire colors did the trick along with the pic of terminal numbers.
This board never fails to help!
Old 08-12-2004, 10:01 AM
