Why doesn't my tach work with HPX ignition?
I'm not sure how to tell for sure if I need the tachometer amplifier for my Electromotive HPX ignition in my '73. Tach doesn't move but I tore the car apart 10 years ago and I think the tach worked then but I don't know for sure. How can I tell what I need for sure?
Thanks, Matt
'73 911 Targa / 2.7 RS spec |
I don't think the early tachs work with HPX. In my case I used a SC tach, works fine.
The signal is different, check the archives.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
Good info, thanks. What is the difference cosmetically?
Matt
off topic but what are you using for cam angle signal??
trigger wheel on the front crank pulley? any pics of your setup because im switching my 3.2 dmecar to a pressure sending setup and will use the flywheel for crank angle but now need cam angle to fire the plugs. thanks
Excell Racing Boca Raton fl |
Biggest issue is that you'd have to buy one for $100 or so. There may be some sort of adapter/amplifier you can use with the HPX, and the early tach, I'm not sure.
Here is a picture of the sensor and trigger wheels on the crank pulley on my engine. This thread (scroll halfway down this page) has more details about the install in my car. 3.0 into 69 911E woes
I should add that North Hollywood speedometer can install SC tach internals into an early tach to maintain stock appearance. I think a couple of guys have gone that route. PartsHeaven has used tachs or try ebay if you need one.
thanks
thanks for the link. now what do you use for the crank angle?
the old sensor the dme used on the flywheel??
