Alan Cottrill's Avatar
CIS to EFI throttle body mod for TPS
big AL
'77 911
Old 08-14-2004, 08:53 PM
I modded my throttle body to use a tps with my megasquirt setup.
here's the parts I used. I made the adapter plate from scrap aluminum.
I drilled and tapped the throttle shaft and the 2 holes in the throttle body used to mount the bracket.
the actuator key is a #10 thumb screw. After I ground it down to fit in the tps I put a nut on it for a lock nut. I had to do some fiddling around to get the angle of the key just right to get full throw on the TPS. Once I got it adjusted I tightened the nut to lock the screw in place.
Once I had prepped the throttle body all that was left was to cut and drill the adapter plate and bolt it together.
after everything was fitted I cut down the bolts that hold the TPS to the plate.
big AL
'77 911
Old 08-14-2004, 09:18 PM
Hilbilly Deluxe
emcon5's Avatar
Outstanding.
Tom
82 911SC Coupe
GTI Cup #43
Old 08-14-2004, 10:53 PM
89turbocabmike's Avatar
Thanks for sharing Alan! I wondered how the TPS was attached to the throttle body, is this normally how it is done or your version? These pics go into my EFI project file.
Old 08-14-2004, 11:36 PM
Thanks Tom!
I'm going the DIY route with my megasquirt install so everything I'm doing is one off.
tbitz has a really nice kit he sells that doesn't use a TPS, it uses MAP for acceleration enrichment.
big AL
'77 911
Old 08-15-2004, 10:53 AM
