-   -   how can I make an 86 faster? (http://forums.pelicanparts.com/porsche-911-technical-forum/178006-how-can-i-make-86-faster.html)
mm86911 08-17-2004 10:47 AM
Assuming you're keeping the 3.2 then think seriously about changing the ring / pinion to 7.31 ratio - instant acceleration improvement for street, track and autox.
MOMO3.2 08-17-2004 11:20 AM
Jeff:
I have an 87 Carrera. All it took was a handfull of laps around a road course circuit to conclude:
(1) My car has more than enough acceleration, (2) My brakes are great, (3) Every $ I spend on performance will go into suspension, seat time, and adding less weight. I do not want a dedicated track car, so a roll cage, harness, and race buckets are a no no for me.
If you want a crisper throttle response, a Steve W chip may be worthwhile for you too. I have had one for a year and it is great.
Finally, I just got back from a 700 mile trip up Hwy 1 in California. It is a lot of high speed mixed with a gaggle of tight twisties. I was NEVER wanting for more hp. A more balanced and grippy chasis would have been nice though.
Good luck.
Mike
Rick Lee 08-17-2004 12:49 PM
Concur with the guys on getting DE time. I've done it in my Carrera and in my 993 and have had my a$s handed to me by older, slower cars with great suspension and more experienced drivers. After my first DE in the 993 I swore I wouldn't spend another dime on HP until I had upgraded suspension and done a few more DE's.
Well, now I'm there. My Bilstein HD's and H&R springs are about as good as it gets, so I'm spending money on another DE and will start planning an engine drop for light-weight flyhweel and RS clutch kit, maybe even a Euro G50/21 gearbox. But this is gratuitous stuff mainly for street driving. A stock Carrera does just fine on the track and you'd be amazed how much you can get out of the car with just more seat time.
Quicksilver 08-17-2004 01:24 PM
To really make it go faster, toss it out of an airplane at about 30,000 feet!
Wayne
http://www.pelicanparts.com/support/...hotbounce2.gif
Bill Verburg 08-17-2004 01:27 PM
The usual way is
  • cams
  • compression
  • displacement
  • gearing
jeff1hughes 08-17-2004 01:29 PM
OK, I'll do some DEs, get the chip, then work over the suspension. Once all that's done I'll drop it out of an airplane at 30,000 feet. Anyone have access to a C-30 that I can borrow?
jeff1hughes 08-17-2004 01:31 PM
Originally posted by Bill Verburg
The usual way is
  • cams
  • compression
  • displacement
  • gearing
What can be done for cams on the Carreras? I haven't heard too much about a better profile on the 3.2s. But, that is why I posted the question!
JeremyD 08-17-2004 01:32 PM
First and number 1 upgrade is the nut behind the wheel (you). Do at least one DE - I found I had plenty of power.
from there - Steve Wong chip, Dansk premuffler, Sport muffler. - you won't gain much for the $$ from SSI's.
From there do a search on Stage II Turbo from Promotive.
Bill Verburg 08-17-2004 01:39 PM
I suggest that a search is in order. There are a whole bunch of guys that have used different cams w/ good results. The main caveat is that the Motronic metering system limits the lumpiness that can be used.
Randy Webb 08-17-2004 02:29 PM
"lumpiness'
- a good term -- not just for cams but for many of the answers posted on this and other BBS's
BTW, you need to think about what is legal, and what is affordable. It is a lot cheaper to do thought experiments than to rush in with a wallet and a wrench. good luck.
Shaun @ Tru6 08-17-2004 06:16 PM
I second everyone who said spend some time on DE.
My 84 is plenty fast with just a weight reduction plan and a SteveW chip, but what made it a great car to drive fast was a complete suspension R&R wtih bigger T bars, Elephant Racing bushings, Bilstein Sports, turbo tierods, lowered and corner balanced.
For weight reduction, I
pulled entire AC
Momo Corse's for driver and passenger
Minimal interior... no back seats, no carpet, console
No spare tire, but a can of fix-a-flat and tire repair kit
Randy Webb 08-17-2004 06:37 PM
SUre a DE helps you drive faster on the track. But reread his comments - he is looking for certain things -- and they aren't particularly well correlated with DE experience.
jeff1hughes 08-17-2004 06:40 PM
Thanks for understanding Randy. But I did get plenty of help from everyone, and I do understand the importance of DE events.
WydRyd 08-17-2004 06:52 PM
Do a search for "Juan Ruiz" on this Forum and you'll see how to make a 3.2 FAAAASSSSSSSSSTTTTTTTTTT!!!!
Steve W 08-17-2004 06:57 PM
Red: stock chip
Blue: performance chip (that you can purchase everyday at Pelican) :cool:
http://forums.pelicanparts.com/uploa...1092794095.gif
From Tomturtle's '88 Clubsport.
dean 08-17-2004 07:03 PM
When I first got my SC it had ok power. But I am a turbo guy so I put a 930 motor in my car. That was the single best thing that I did to my car. It made my Porsche go like it should.
Dean
89911 08-17-2004 07:17 PM
Dean, lets keep it real. I would not put a engine transplant in the same catagory as a chip and exhaust modifications. I would hope your car is faster. Not everyone wants to dump the engine they just got with their car and then spend another $10,000 for engine work. I think they would of just bought a turbo instead.
dean 08-17-2004 08:02 PM
Jeeze I was just telling the original poster what I did to my car to make it faster. I don't think I implied that a turbo is in the same catagory as a chip and exhaust.
Dean
rdane 08-17-2004 08:52 PM
Any particular reason the dyno graph is scored at a 6200rpm instead of a more realistic chip comparison at 6K?
Steve W 08-17-2004 09:07 PM
Basically with the stock chip, peak hp is attained at 5900 rpm, as shown the owner's manual and multiple dyno charts, as can be seen here:
http://www.911chips.com/dyno.html
With the performance chip, the hp contines to rise past 5900 and a new peak is reached at around 6200 rpm. As you can see, at 6200 rpm, the engine has gained 22 rear wheel hp, an equivalent of 26 crank hp. That is a 12% gain in power. Past 6000 rpm, the engine power seemingly continues to rise and pull until the rev limiter hits, whereas with the stock chip, the engine seems like it hits a wall after 6200.
