Seal Around Rear Quarter Windows
I'm installing rear quarter windows and I have a question about the installation. I understand there is no weatherstrip adhesive on the outside part of the black seal where it contacts the car body but should I put weatherstrip adhesive where the chrome window frame sits in the inside part of the black seal?
It seems like I should but I want to check with everybody first.
Thanks,
nick
1970 911 E (restoring)
Old 10-11-2003, 01:48 PM
You do not have permissi
john70t's Avatar
The seal fit is very tight-about an hour per and sore thumbs to install- so it should not need it and the half dried glue will make high spots. Do the flat side first and roll the bead into the groove, have fun.
Old 10-11-2003, 10:00 PM
No glue.
Old 10-11-2003, 10:04 PM
sithot's Avatar
Inner seals (glass) are easy. The outers are at least worth a pair of sore thumbs. No glue, no weatherstrip adhesive and no silicone.
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 10-11-2003, 10:17 PM
Shaun @ Tru6's Avatar
no glue.
I wrapped mine around as best I could, then let sit in very hot water in the tub for an hour (I am not married) and then a hair dryer made the job quite easy.
Tru6 Restoration & Design
Old 10-11-2003, 10:21 PM
What?!?!
DonDavis's Avatar
Any new "tricks" on this task? I just spent about an hour and got half way on ONE window. My thumbs and fingers are toast.
I'm using a small Orangewood stick to help roll the seam into the groove approx half-inch at a time. Thought about using a little dish soap but I just know that would turn bad.
I can see it know...."Almost there...a little more to go.... just about done...." and then the window would slip out of my soapy hands and crash to the garage floor, shattering. That would cost me a LOT of beer. You know, for the anger/sadness treatment.
So, if anyone has any "Best Practice" tips, I would appreciate it.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 08-16-2004, 11:11 PM
do a search.
some 1/4 are different than others. I think JW did some good posts on this a while ago.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-16-2004, 11:16 PM
What?!?!
DonDavis's Avatar
Ron....dude... I did do a search. That's how I found this old one. At least I didn't start a new thread. Some older ones said "Yep, that gasket sucks. Sore thumbs, but you will get it" or several threads about the fixed 1/4 windows and the cord trick.
Now, either help with my windows or post some hot chick pics! Or sumpthin'!
When's your next BIG ride?
Old 08-16-2004, 11:33 PM
Did you read through this thread?
Really, it was pretty easy after soaking in hot water. I can add that that a small screwdriver helps feed in the molding.
Old 08-17-2004, 04:34 AM
What?!?!
DonDavis's Avatar
Shaun, I was wondering if you put the whole window or just the gasket in the water. Sounds like you put the whole window. I would think that if it were just the gasket then it would cool before you could get finished.
Also, I don't trust myself with a screwdriver for this task. I'm using an orangewood stick.
Thanks.
Old 08-17-2004, 08:15 AM
Don, definitely put the whole thing in hot water, yes, a screwdriver means you have to be be very careful. I took the slightest edge off the corners with a grinder, and it worked great. Just be very careful and "feel" the rubber.
Old 08-17-2004, 10:55 AM
Ron....dude... Now, either help with my windows or post some hot chick pics! Or sumpthin'!
My ride has been just transformed. I'm tweaking now and will do a few 2-10 day rides to feel it out. If it can'r roll for at Least 10k miles, it's not tweaked enough.
hot chicks.. for fair and balanced reporting eyeball this babe.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2004, 03:49 PM
don't miss the crack.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2004, 03:55 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
i used soapy water, it still was a pain, but it worked.
<<-- i bet the girl above sets off the metal detectors at the airport!
Marc
Old 08-17-2004, 04:40 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2004, 11:09 PM
What?!?!
DonDavis's Avatar
Butthead voice- huh-huh-huh-huh-huh
Old 08-17-2004, 11:34 PM
they get $200 each.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-18-2004, 04:27 AM
they get $200 each.
I've got 2 early fenders in good condition (although not as good theirs!) but do you think they'd be interested in a trade?
Old 08-18-2004, 04:30 AM
I could ask them. They seem to be very receptive females. Maybe if I can explain how stiff the times are now-a-days.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-18-2004, 04:38 AM
