-   -   How far should the AAR open up??? (http://forums.pelicanparts.com/porsche-911-technical-forum/178133-how-far-should-aar-open-up.html)
radcon 08-17-2004 02:25 PM
After chasing cold start problems for many months, I am now starting to remove each CIS item one at a time to inspect it. I took off the Auxiliary Air Valve today to check it out. Threw it in the freezer for quite a while and it was still only half way open. Should it be fully shut when the engine is warmed up? How far should it be open:
At freezing?
At room temp(say 80-85 degrees)?
When engine is warmed up?
Thanks for your help.
ubiquity0 08-17-2004 03:18 PM
The AAR should definitely be fully closed when the car is warmed up. Mine is maybe 1/3 open at 70 degrees.
radcon 08-17-2004 07:13 PM
Hooked up the multimeter and got 33 ohms across the element. I think that is what it should be. Hooked it up to a hot lead and watched it go fully shut in about five minutes. So the AAR seems to be working OK. I'm thinking there has to be a big air leak somewhere in the cold start circuit. The AAR is open when the engine is cold, but I'm not getting the increased idle when I first start the engine. Next guess??
kstylianos 08-17-2004 07:39 PM
The mix is too rich during warmup? Check your cold pressures to see if they are in spec.
smestas 08-17-2004 08:56 PM
Here's a good AAR thread
http://forums.pelicanparts.com/porsche-911-technical-forum/112138-aar-good-bad.html
Paulporsche 08-18-2004 02:05 PM
I agree w/ kstylianos. It might be mixture related or WUR.
Is it also possible that in Aug in Fl you won't get an increased idle @ startup?
