How far should the AAR open up???
After chasing cold start problems for many months, I am now starting to remove each CIS item one at a time to inspect it. I took off the Auxiliary Air Valve today to check it out. Threw it in the freezer for quite a while and it was still only half way open. Should it be fully shut when the engine is warmed up? How far should it be open:
At freezing?
At room temp(say 80-85 degrees)?
When engine is warmed up?
Thanks for your help.
'80 Targa - Gone. No P-car until I have more time and money
My Pelican Owners Page
Old 08-17-2004, 02:25 PM
The AAR should definitely be fully closed when the car is warmed up. Mine is maybe 1/3 open at 70 degrees.
Old 08-17-2004, 03:18 PM
Hooked up the multimeter and got 33 ohms across the element. I think that is what it should be. Hooked it up to a hot lead and watched it go fully shut in about five minutes. So the AAR seems to be working OK. I'm thinking there has to be a big air leak somewhere in the cold start circuit. The AAR is open when the engine is cold, but I'm not getting the increased idle when I first start the engine. Next guess??
Old 08-17-2004, 07:13 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
The mix is too rich during warmup? Check your cold pressures to see if they are in spec.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 08-17-2004, 07:39 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Here's a good AAR thread
Is This AAR Good or Bad?
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 08-17-2004, 08:56 PM
Designer King
Paulporsche's Avatar
I agree w/ kstylianos. It might be mixture related or WUR.
Is it also possible that in Aug in Fl you won't get an increased idle @ startup?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-18-2004, 02:05 PM
