Those who have installed headers-please advise me...
I just got my new B&B headers in. I'm 90% sure I'm going to drop the motor for a rebuild the end of the year. Do I wait until then for the headers, or do I take my chances now, assuming the risk of breaking studs, etc?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Insert Tag Line HERE.....
Breaking exhaust studs is not too common. Just make sure you spray them in rust penetrate a day before hand, and you shouldnt have any problems. If they get stuck, most of the time the stud will come out with the nut.
Marc |
RETIRED
Easier when the engine is out.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I figured they'd be easier when engine is out, but I figure I've got 2 DE's before I pull the motor, and they SHORE IS PURDY!!
I just went through the same ordeal a couple of weeks ago. I couldn't wait. So I bit the bullet and installed my B&B headers with the engine in the car. I sprayed some penetrating fluid on the studs an hour or two before I started removing the nuts. The nuts came off without any trouble at all and the new headers went on perfectly. YMMV, of course. Best of luck to you, whatever route you take.
Brian 1981 930 |
Make sure you got the headers that allow you to adjust the valves when their on. I had a set of B&B's that would not allow the valve covers to clear so you had to drop the whole system to do a valve adjustment :-(...
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
Thanks Brian: I'll stay positive on this. I've got plenty of PB, and oxy-acetylene, and time. What muffler did you go with? I'm going with a Fabspeed piece made for B&B headers. I've heard to much bad on B&B mufflers.
Breaking a stud, although maybe not "common", does happen. I have done it before and also know a few who have as well. Soak in some form of penetrating oil and use a torch to get the nuts good and hot and then get a wet rag on them to quench them and break the rust free. Also, I have had success just using a 1/4 inch drive ratchet so that I do not get too much torque on the nuts. The allen head barrel nuts should not be a problem. The fact that you are concerned about this is a good thing, you will probably be careful enough to not have any problems at all.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Ed - I went with a Fabspeed muffler too. Great choice. I absolutely love mine.
Brian 1981 930 |
