efhughes3's Avatar
Those who have installed headers-please advise me...
I just got my new B&B headers in. I'm 90% sure I'm going to drop the motor for a rebuild the end of the year. Do I wait until then for the headers, or do I take my chances now, assuming the risk of breaking studs, etc?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 08-19-2004, 06:37 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Breaking exhaust studs is not too common. Just make sure you spray them in rust penetrate a day before hand, and you shouldnt have any problems. If they get stuck, most of the time the stud will come out with the nut.
Marc
Old 08-19-2004, 06:50 PM
RETIRED
Joe Bob's Avatar
Easier when the engine is out.....
2012 ML350 3.0 Turbo Diesel
Old 08-19-2004, 07:07 PM
efhughes3's Avatar
I figured they'd be easier when engine is out, but I figure I've got 2 DE's before I pull the motor, and they SHORE IS PURDY!!
Ed Hughes
2015 981 Cayman GTS
Old 08-19-2004, 07:48 PM
81 930's Avatar
I just went through the same ordeal a couple of weeks ago. I couldn't wait. So I bit the bullet and installed my B&B headers with the engine in the car. I sprayed some penetrating fluid on the studs an hour or two before I started removing the nuts. The nuts came off without any trouble at all and the new headers went on perfectly. YMMV, of course. Best of luck to you, whatever route you take.
Brian
1981 930
Old 08-19-2004, 07:55 PM
Make sure you got the headers that allow you to adjust the valves when their on. I had a set of B&B's that would not allow the valve covers to clear so you had to drop the whole system to do a valve adjustment :-(...
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 08-19-2004, 07:59 PM
efhughes3's Avatar
Thanks Brian: I'll stay positive on this. I've got plenty of PB, and oxy-acetylene, and time. What muffler did you go with? I'm going with a Fabspeed piece made for B&B headers. I've heard to much bad on B&B mufflers.
Ed Hughes
2015 981 Cayman GTS
Old 08-19-2004, 08:00 PM
Jeff Alton's Avatar
Breaking a stud, although maybe not "common", does happen. I have done it before and also know a few who have as well. Soak in some form of penetrating oil and use a torch to get the nuts good and hot and then get a wet rag on them to quench them and break the rust free. Also, I have had success just using a 1/4 inch drive ratchet so that I do not get too much torque on the nuts. The allen head barrel nuts should not be a problem. The fact that you are concerned about this is a good thing, you will probably be careful enough to not have any problems at all.
Jeff
www.turn3autosport.com
Old 08-19-2004, 08:18 PM
81 930's Avatar
Ed - I went with a Fabspeed muffler too. Great choice. I absolutely love mine.
Brian
1981 930
Old 08-19-2004, 11:35 PM
