dkm_chgo's Avatar
'70T engine number
Hi,
I just bought a 1970 911T Targa with a VIN #9110112515 and an engine number of 901 106101 5R. Can anyone tell me if this VIN and engine are correct? If not, is it a T engine, E engine, or S and what production year? Thanks.
dkm
'72T Targa w/2.2S MFI (sold circa 2010)
Old 08-22-2004, 06:54 AM
andrew15's Avatar
The VIN number shows that it's a 1970 911T
The engine # you gave though looks like a casting #
The real engine ID #s are stamped near the fan housing support on the right side of the engine (see below pic)
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 08-22-2004, 07:15 AM
dkm_chgo's Avatar
Hi,
Thanks for the info, but is there any disassembly needed in order to read the numbers?
Old 08-22-2004, 07:28 AM
andrew15's Avatar
nope - just take a look at the base of the fan on the RIGHT hand side - the upright where the fan housing mounts should show the engine serial #
Regards,
Andrew M
Old 08-22-2004, 08:02 AM
Early_S_Man's Avatar
Porsche Crest
Make that the RIGHT hand side of the fan housing support ... looking at the engine as it sits in the engine bay!
You will probably need a good cleaning rag to wipe off the dust and dirt over the engine 'Type Number' ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-22-2004, 09:46 AM
andrew15's Avatar
Whoops - the Other Left!!! - It's on the right side as Warren points out - I'm going to plead hangover from last night....
AM
Old 08-22-2004, 10:09 AM
dkm_chgo's Avatar
Hi,
Thanks for the info...The engine number is 6117859 and the engine type number is 911707 or 911/07, I couldn't quite make out the fourth number/character from the left. Thanks.
dkm
Old 08-22-2004, 04:04 PM
andrew15's Avatar
Engine Type 911/07 is a 2.2L 911T (USA)
Engine # 6117859 looks to be a 1971 motor (610xxxx were 1970 911T)
If it is a 1971 version engine, it's a good find as they had piston oil squirters.
Regards,
Andrew M
Old 08-22-2004, 04:19 PM
dkm_chgo's Avatar
Thanks, Andrew
Old 08-22-2004, 04:37 PM
