justesen's Avatar
Can I add an AC vent?
Here is a picture from "seat level on the drivers side" in my 77 911 of the "HVAC Box" on the firewall.
Can I drill a 2 1/2" hole in the air box without damaging anything inside? I'll then run an AC hose to a vent that will be mounted on top of the console. This is a "home made" attempt to get better air flow than provided by the stock vent system.
Thanks,
Jay
77 911S
I know you believe you understand what you think I said, but I am not sure you realize that what you heard is not what I meant!
Old 08-24-2004, 12:07 PM
I recall something about an oversize vent that might do the same thing. Maybe someone can recall the details.
'80 SC
Old 08-24-2004, 12:54 PM
Designer King
Paulporsche's Avatar
I think that will work.
BTW what is that seam? Was this area modded by you or a PO?
Let us know how it works out.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-24-2004, 01:11 PM
justesen's Avatar
Paul,
As far as I know, the seam is "stock". I'm the second owner and the original owner had nothing done to the car. It only has about 37,000 miles on it.
Jay
Old 08-24-2004, 01:35 PM
david914's Avatar
Try this...http://www.scottsind.com/Navigation/PartsForSale/PartsForSale.htm
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 08-24-2004, 02:24 PM
Designer King
Jay,
I have the bulkhead vent that David shows in his link. It goes in that area. It came w/ the car so I don't know what it costs. It works fine. You may get away w/ your low cost variation just fine. You just won't have the directability of the vent.
Paul
Old 08-24-2004, 04:14 PM
justesen's Avatar
Paul,
Does the vent mount right on the "air box" under the dash? Do you have a picture?
Thanks,
Jay
Old 08-24-2004, 04:20 PM
Designer King
Jay,
I don't have a pic, but the vent sits on the face of the box, just below the seam. I just noticed I have one too. When looking at it from the seat, the centerline of the vent is about 1/2" to the left of the right edge of the console.
Paul
Old 08-24-2004, 07:32 PM
justesen's Avatar
Thanks Paul. I've ordered a vent that should screw right to the box as long as I cut the holes correctly!
Regards,
Jay
Old 08-25-2004, 03:39 AM
