JED
CIS fuel line sources??LEN MIA?
I’ve had a failure of my hard line cracked just past the crimped fitting at the front near the fuel pump. After reviewing the forum all advice said to use Len, called his shop they said he retired, tried a old email no luck.
Anyone have a source. Had to cut polymiad line and just barely got a heated section of 3/8” ID over hard line to make it home from firehouse, non fuel injection SAE 30RZ. Not the recommend solution I know but what was available at ACE. Guess I’m in for the fun and exciting task of replacing tunnel lines. Interesting my 74 has the poly lines and the pump is at the front. Is there a more permanent temporary fitting that can be used on the short ploy line that I have left.
Try this email. He is still active, at another location.
len.cummings at verizon.net
1983SC RoW |
JED
I will try that thank you. Anyone have a opinion on a fix for my conditions until I get new lines?
Fuel lines..........
Use fuel injection rated fuel hoses and Oetiker type clamps. Make sure the rubber hoses are rated for FI application not just fuel hose application. Plus they are easy to fabricate compared to the polyamide plastic tubes. Tony |
![]() I am happy to help. Please email me at: Len.Cummings at verizon.net Len
![]() ARCSinAK - I believe I am caught up on all my emails, but do not recognize or find your message. It always helps to identify your request when your Pelican name is included. How can I help you? Len.Cummings at verizon.net (Please use @ in place of the "at" above in my email address.) Thank you. Len
I have a '78 SC with the OEM plastic fuel lines. I have an opportunity to purchase a complete CIS system with the metal lines for a very reasonable price. I see that Paul Mason and Len Cummings both offer fuel line replacement systems. And Tony suggests that replacing the fuel lines can be done by fabrication.
Can anyone comment on which of the options available is a) safest and b) easiest? I am also going to face this issue when I restore my '73.5 CIS T. Thanks for your input.
Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 |
![]() I can advise you to go with the all metal lines on your motor. Not that the Polyamide lines are not good, as they are practically bulletproof. But the steel lines are bulletproof, so buy them if you can. I am happy to help with chassis lines that are Polyamide. Far easier to install than any other option, and they will last the lifetime of the vehicle. Len
Thanks for the advice Len. Sent you an email.
Just tried sending you a PM but it seems your inbox is full. I also emailed you regarding my 77 911. Let me know, thanks!
1977 Porsche 911S Targa 1981 BMW 520 Euro Spec |
He doesnt do PM's. Email only
Yeah thanks. I got a hold off him via email tonight.
